Is this where you get ECU updates
Old Apr 11, 2005 | 07:11 AM
MDRX8's Avatar
http://www.mazdatechinfo.com/home/ES...opCatagory.asp
Can they be loaded with a cannzoomer unit and laptop?
Old Apr 11, 2005 | 08:00 AM
Sigma's Avatar
That's where the dealer gets them from, yes. But you can't. It takes a very special piece of equipment to flash the ECU/PCM. You have to go to the dealer to get an update.
Old Apr 11, 2005 | 11:59 AM
zoom44's Avatar
thats not where the dealers get them from
Old Apr 11, 2005 | 04:32 PM
Jdunsh's Avatar
JDunsh
I just made my apointment with the dealership to get the N flash, no problems at all, and won't cost me anything.
Old Apr 11, 2005 | 04:38 PM
therm8's Avatar
Bummed, but bring on OU!
from the harrison r&d site (maker of the CanScan unit)
UPDATE 1-4-2004 - We have received many questions about the Passthrough Programming capability which will be available on the CANScan-USB. The SAE-J2534 is a specification for a software/hardware interface which has the capability for reprogramming or reflashing vehicle PCM's. The software component is a "dll" or dynamic linked libary, which is a special form of a Windows program used in this case as the reprogramming interface to a Windows application. Some automakers have made available, for a very reasonable cost, the Windows application which interfaces with the J2534 dll. By using the manufactures application and our dll and hardware you can reprogram the PCM's using files supplied by the manufacturer.
What you will need to reflash a ECU: In addition to the CANScan-USB and J2534 software, you need a programming voltage supply and a programming cable, both of which we will sell. The programming voltage supply will require either 2 or 3 solder connections to the CANScan PCB depending on the power supply used. You will also need a Windows application which communicates with the J2534 dll and the ECU Flash file. Both of those items are available from some auto manufactures web sites for less than $30.00. See www.mazdatechinfo.com/home/ecmDetail.asp for an example.
Old Apr 12, 2005 | 06:19 PM
Sapphonica's Avatar
PingMobile
Thumbs up DIY PCM updates
Thanks Therm8!
This will come in handy for those of us who don't want to get jacked by the Mazda dealer for having modified intake/exhaust/etc.
Old Apr 12, 2005 | 09:53 PM
therm8's Avatar
No problem, this thread reminded me that they were working on the pass-thru device, and I have the site bookmarked. Now to just get a cheap laptop with usb 2.0 ports.
Old Apr 13, 2005 | 12:25 AM
I'm a bit shocked that Mazda is not listed here:
http://www.ime-actia.de/passthru/oem_flash_info.htm
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Evan Gray
Sep 26, 2015 12:30 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
