Water Wetter
Old Apr 5, 2005 | 11:45 AM
Rotario's Avatar
Long Member
Water Wetter
Howdy Folks,
Has anyone used Red Line's "Water Wetter" in their cooling system? I currently use it in my liquid-cooling system for my computer to good effect (dropped average temps by about 2c), but have never tried it in the much higher heat application of an automobiles cooling system. Any pros or cons from anybody that has used it (or is using it)?
http://www.redlineoil.com/products_coolant.asp
Thanks,
Bill
Old Apr 5, 2005 | 12:16 PM
Dark8's Avatar
Ride Naked!
https://www.rx8club.com/showthread.p...t=water+wetter
Old Apr 5, 2005 | 01:46 PM
Rotario's Avatar
Long Member
Thanks, Dark8. Somehow I missed that thread when I searched.
Best,
Bill
Old Apr 5, 2005 | 02:02 PM
KYLiquid's Avatar
Oil Injection
it works best with just plain distilled water and the water wetter addative, no antifreez...obviously this is for summer only...and i still worry about corrosion and electrolosis, so i have always used a 60/40 water/coolant and a bottle of watter wetter in my car.
there is also a zero pressure coolant, cant remeber the name, but some buddys of mine ran it, never got an actual reading on it, but the stock coolant gauge was normaly at 12o'clock and with the zero pressure coolant it was at 11o'clock.
the stuff was pretty expensive, about 2x what a 1 gallon bottle of antifreez cost and you dont mix it with water, its straight from the jug to your car. also you run a non-presureised radiator cap. Interesting stuff
Old Apr 5, 2005 | 02:06 PM
KYLiquid's Avatar
Oil Injection
ahh i found it
"Evans NPG+ is a special waterless coolant with a 375 degreeF boiling point at zero psi and does not freeze until -70 degreesF (it contracts and gets 'slushy'; not really freezes). Because it is non-aqueous (no water), corrosion is virtually eliminated and there is no need to change it yearly. In fact, it has been tested for hundreds of thousands of miles with no signs of degradation, according to Evans. While the initial cost is high, compared to ordinary coolant, it is a bargain over the life of the vehicle."
http://www.pineappleracing.com/Prod-EvansNPG.html
Old Apr 5, 2005 | 02:58 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Originally Posted by Rotario
Howdy Folks,
Thanks,
Bill
Several of the guys on my old Miata list complained about the sludgy residue it left inside the coolant tank and radiator cap, making them speculate that it was leaving that gunk throughout the cooling system. Based on that, I won't touch it with a 10 foot pole...
Old Apr 5, 2005 | 03:31 PM
SHAG1's Avatar
Water Wetter was the first thing I added to the car. Just poured one bottle in the reserve tank.
05rx8mazda
Nov 28, 2015 09:42 AM
arexatemate
Oct 4, 2015 12:36 PM
jDt!
Oct 2, 2015 04:04 PM
DG07
Sep 28, 2015 10:58 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
