View Full Version : Anyone selling the 6spd rx8 oem brake calipers??
sbu12g
04-03-2005, 03:59 AM
Hi guys,
i bought a pair of slotted brake rotors but its a wrong size as my ride is an auto trans with smaller caliper hence i am thinking of changing from my current to the 6 spd rx8 caliper, inorder to fit my rotors. pls advise.
thanks
morganoh
04-03-2005, 09:29 AM
Hi guys,
thanks
Are u still using the original 16inch rim?
If yes I do not think that u can use the 6spd RX8 caliper. cos the inner diameter of a 16inch rim is too small
M-ster
04-03-2005, 11:15 AM
i thought i read some where before, the calipers of the 6spd and auto is the same, the only different are the size of the rotors. Is there such things as changing the caliper's mount??
morganoh
04-03-2005, 12:01 PM
I may be wrong and confuse.
Is it that the caliper are the same or the rotor are the same size between the 210 hp and the 230 hp car.
Or both the caliper and rotor are different between the 210 hp and 230 hp cars???? :confused:
sqflyer
04-04-2005, 01:42 AM
Both caliper and rotor are different. Not sure if standard 16" rims will fit. Bro... try asking sgrenesis. He upgraded to 6-spd calipers, rotors and Mazda 18" rims.
sbu12g
04-04-2005, 09:19 AM
hi guys,
My rides have an 18 inche rims on it, hence i am looking for a 6spd calipers to fit my new rotor from usa....pls help..
Thanks man
