Airbag issue - install a racing seat
Old Apr 1, 2005 | 07:20 PM
sammytcl's Avatar
I want to install a recaro racing backet seat since I bought my 8. The reason why I have not done yet is the stock seat airbag issue. I already did searching the forum so many times and it seems no one has changed their seat AND solve the airbag problem. Here is what I want to accomplish:
1. replace the driver leather seat with recoro pole-position backet seat
2. have an adapter / resister (how many ohms) plug in the airbag sensor to fool the airbag module thinking that the seat airbag is still there
3. have all the remaining 7 airbags still operational
So anyone has any idea on:
1. what resister I should use for the seat airbag, or is there any adapter available?
2. if I leave it without any resister/adapter, will the remaining 7 airbags still operational (I know the dash airbag light is going to come on)?
Thanks a lot!!
Sammy
Old Apr 1, 2005 | 07:54 PM
expo1's Avatar
He's as bad as Can
I have tangled with this issue and I don’t think you will be able to trick the system into thinking there the OEM seat is installed with a .10 resister. Without knowing exactly what you are doing you risk damaging some of the electrical system. I highly doubt the others bags would not fire simply because the system finds a problem with ONE of the bags in the car. That would leave Mazda open to huge liability claims. This is my suggestion, I have not done this but it could work.
First figure out which of the two connectors under the seat (if you have a power seat) is for the air bags and cut it off. Then get some extra wire of similar gauge and splice the connector into the harness of the passenger side seat. So what you are doing tricking the car into thinking BOTH seat installed air bags are working. Again I have not done this but if it doesn’t work you can re-attach the connector no harm, no foul.
Old Apr 1, 2005 | 11:54 PM
sammytcl's Avatar
Thanks for the info expo1. I never thought about that option before. However here are the questions:
1. if the driver side airbag connector is connected to the passenger side airbag, when there is a side impact (accident) to the driver side, the passenger side seat airbag will deploy, am I right?
2. would connecting two connectors into one airbag change the resistant/current/voltage and end up having two mul-function airbag codes (both driver seat and passenger seat), or even deploy the passenger seat airbag when connecting it?
Thanks again for the info.
Sammy
Old Apr 2, 2005 | 07:50 AM
expo1's Avatar
He's as bad as Can
** just guessing**
1, Yes but at that point does it matter?
2, If the airbg light goes on yes, only a accident should set off the bags.
These threads might be of use
https://www.rx8club.com/series-i-interior-audio-electronics-24/anyone-modify-lower-drivers-seat-43784/
https://www.rx8club.com/showpost.php...0&postcount=10
Old Apr 4, 2005 | 04:30 PM
sammytcl's Avatar
It looks like nobody changed their seat with the airbag issue solved! However I know that sti has the seat airbag too but they would be able to put a 3.2ohm (or mabe 3.3) resistor to fool the computer. Again any info would help a lot.
Thanks.
Old Apr 4, 2005 | 04:43 PM
PUR NRG's Avatar
Does this sound like an elementary excercise in electronics?
1. Figure out wiring diagram for seat connector.
2. Unplug connector.
3. Apply multimeter across airbag leads to establish open and closed resistance.
________
Peachy
Old Apr 4, 2005 | 06:56 PM
sammytcl's Avatar
I was told by so many people/mechanics that the current/voltage of a multimeter is high enough to deploy an airbag.
Old Apr 4, 2005 | 07:19 PM
PUR NRG's Avatar
Huh? I'm talking about the connector on the seat. I'm not aware of an airbag within the seat itself.
________
Kitchen Measures
Old Apr 4, 2005 | 07:23 PM
army_rx8's Avatar
X-Sapper
that is where teh side impact airbag is housed in the front seats, are they not? least that's wher emine are:p
Old Nov 10, 2005 | 07:09 PM
mazdaexe's Avatar
anyone have a solution to this?
Old Nov 10, 2005 | 07:31 PM
Im_DANomite's Avatar
I love GOOOLD
you can't deploy an airbag checking resistance. checking amperage...possible. i don't know why you would tho.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
reverse01134
Jul 16, 2015 10:27 PM
AussieGray
Jul 16, 2015 03:58 AM
