Sound after turning car off
Old Mar 26, 2005 | 09:10 PM
Peregrine8's Avatar
On Cloud 8
Since I just got the car yesterday, maybe I'm hypersensitive to anything weird, but I came home tonight from eating out with friends and when I pulled the car into the garage, stopped it and got out, there was a strange sort of low whirring sound coming from the back of the car, it sounded sort of like the car was still idling after it had been turned off. It stopped after 45-60 seconds I would guess.
Is this normal or something I should be watching for in the future? I've also noticed a lot of heat pinging sounds after I turn it off but I figured this would be normal for such a hot running engine.
Old Mar 26, 2005 | 09:14 PM
snap-on's Avatar
It is the car running a EVAP test..It runs this to check the fuel cap.
Old Mar 26, 2005 | 09:16 PM
tiggerlee's Avatar
May Cause Anal Leakage
Are you sure the noise was coming from the rear? The cooling fan turns on automatically even shortly after the car is turned off. It will run for a few seconds then turn off.
Old Mar 26, 2005 | 09:18 PM
tiggerlee's Avatar
I learned something today. Interesting, I have yet to hear that. I assumed he meant the fan running.
Old Mar 26, 2005 | 09:20 PM
Peregrine8's Avatar
On Cloud 8
Well I did get gas on that trip, so maybe it runs it at the next stop after that?
Old Mar 26, 2005 | 09:21 PM
snap-on's Avatar
The EVAP pump sound is from a small electric motor that pressurizes the tank. It usually runs about a minute..
Much fainter sound than the fans...
Old Mar 26, 2005 | 09:22 PM
snap-on's Avatar
It will test after you add 5 gallons of gas to the car.
Old Mar 26, 2005 | 09:25 PM
Peregrine8's Avatar
On Cloud 8
Well at least I know it's not anything to worry about. I wouldn't have a problem with the fan running, it was just strange hearing something coming clearly from the back of the car for the first time. Thanks Snap-On.
Jaco Greyling
Jan 6, 2019 08:39 AM
Dokuji
Nov 1, 2016 02:51 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
dbarber
Jul 25, 2015 01:34 PM
ironj221
Jul 16, 2015 10:16 PM
