drive belts..?
Old Mar 23, 2005 | 12:59 PM
SharkDiver's Avatar
ZoomZoom
drive belts..?
hey all,
I installed the SR pulleys yesterday and was wondering how tight I should keep the belts at?Is there a simple rule-of-thumb?They are pretty tight but I dont want them to tight.
thx,shark
Old Mar 24, 2005 | 10:48 AM
SharkDiver's Avatar
ZoomZoom
Old Mar 24, 2005 | 11:23 AM
Nubo's Avatar
Lubricious
Tightness is usually expressed as x amount of deflection with y amount of pressure at the midpoint of the belt. Should be in the shop manual.
Old Mar 24, 2005 | 11:33 AM
Go48's Avatar
Originally Posted by SharkDiver
Go to the link below and read about it:
http://www.hi-impact.org/ryang/modif...ineDetails.pdf
Old Mar 24, 2005 | 12:13 PM
SharkDiver's Avatar
ZoomZoom
thx..
Old Mar 24, 2005 | 12:39 PM
SharkDiver's Avatar
ZoomZoom
link not working...
Old Mar 24, 2005 | 01:26 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
The shop manual states there should be a 4.5-5.0mm deflection for the alternator belt, and 3.5-4.0mm for the AC belt, given a pressure of 98N (22lbf) at the center of the belt between the pulleys. They specify a special tool to measure the tension and deflection... but I'm sure you can find something at the autoparts store (or just wing it : ).
Old Mar 24, 2005 | 02:02 PM
Go48's Avatar
link not working...
That link leads to a PDF file so you need Adobe Reader/Acrobat Reader on your system in order to view the page. It is slow to load, so be patient. Once the document comes up, go to page 4 and 5 for drive belt information.
Old Mar 24, 2005 | 03:30 PM
SharkDiver's Avatar
ZoomZoom
Ok,Thanks all.
shark
xAgyex
Jun 3, 2026 03:47 PM
ktec
Jun 26, 2021 10:18 AM
wayloco
Sep 1, 2015 09:03 PM
GrAfiX
Aug 24, 2015 08:08 AM
arjunmshah
Aug 6, 2015 10:56 AM
