VATN Turbos (aka Aerocharger)
Old Mar 21, 2005 | 10:38 AM
Magic8's Avatar
Mazda Mole
Okay ex-Miata (or ex-NSX) owners, someone must know something about this. What was this like and what was its reliability? Any of these things still running today? It looks pretty complex but to me the advantages seems to outweight the downside on the complexity. This turbo is definitely great for a remote turbo application (i.e. turbon in the muffler area.)
Apparently they stopped producing these for a while and now a company called HiPerformance bought off the patent and plan on manufacturing these things again.
HiPerformance, LLC
Old Mar 21, 2005 | 10:44 AM
Magic8's Avatar
Mazda Mole
Just called the manufacturer.
They don't make single turbos that are big enough to run at the required airflow for RX-8. But definitely can run twins. Big downside is the cost. $1895 per turbo!!!
Old Mar 21, 2005 | 12:47 PM
rotarygod's Avatar
I believe the big Ford Diesel trucks use VATN turbos. They are pretty big.
Old Mar 21, 2005 | 01:15 PM
burnoutking999's Avatar
thats right...the KING!
I am sure ive read about this on here before. Didnt someone kick this idea around before from another company?
Old Mar 25, 2005 | 01:08 AM
guitarjunkie28's Avatar
port hacker
these would be really cool for a non-sequential twin setup
Old Dec 24, 2009 | 02:34 AM
Steffiex0's Avatar
*bump*
https://aerocharger.com/shop/index.p...rocharger.html
Old Dec 24, 2009 | 06:55 AM
Kane's Avatar
Senior Member
I sure wouldn't mind rocking one of these -
Old Dec 24, 2009 | 08:50 AM
arghx7's Avatar
Variable turbine geometry is pretty cool. Ford uses them on their current generation diesels. Those turbos don't have internal wastegates at all, but on diesel applications that isn't very important.
Here is a diagram of the variable turbine geometry on the newer generation of Ford diesels:
Old Dec 24, 2009 | 08:54 AM
arghx7's Avatar
And here is how it works. Notice how the VGT actuator uses duty control without a wastegate. That means that the exhaust manifold and other aspects of the turbo system were carefully designed to make boost controllable.
Attached Thumbnails VATN Turbos (aka Aerocharger)-vgt_turbine_control-valve.jpg   VATN Turbos (aka Aerocharger)-vgt_turbine_high_speed.jpg   VATN Turbos (aka Aerocharger)-vgt_turbine_low_speed.jpg   VATN Turbos (aka Aerocharger)-vgt_turbine_mid_speed.jpg   VATN Turbos (aka Aerocharger)-vgt_turbine_operation.jpg
Old Dec 24, 2009 | 10:31 AM
Mawnee's Avatar
I divide by zero
Wow thats pretty cool!
Old Dec 24, 2009 | 11:17 AM
tech b's Avatar
Don't the veins get stuck on most gasoline applications?
Old Dec 24, 2009 | 01:41 PM
Steffiex0's Avatar
But building a system around one would be problematic...since it would have to be ground up work...
Old Dec 24, 2009 | 01:44 PM
Kane's Avatar
Senior Member
^^^This is true.
Old Dec 24, 2009 | 04:21 PM
MazdaManiac's Avatar
I had one on my Miata for about a year.
Well, I OWNED on for about a year.
It went back to Aerocharger 3 or 4 times to have the bearings replaced.
It was stupendously fragile.
I would imagine the Garrett version is superior, but for application it is totally unnecessary because of our extremely high exhaust energy vs. power requirements.
Old Dec 26, 2009 | 08:53 PM
smi_motorsports's Avatar
Not new........ This turbocharger design is used in all 997 Twin-turbo 911s. First mass produced gasoline application award goes to: 1989 Dodge Shelby CSX.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
