Having Stalling Issues with Greddy Kit, Anyone Else?
Old Mar 18, 2005 | 12:17 PM
Booosted's Avatar
When I stop at a light or pull in my drive way I stall out, not all the time but sometiems, im wondering if anyone else has had or is having this issue and how to solve it
Old Mar 18, 2005 | 12:30 PM
loube's Avatar
Make sure that you have placed the gasket for the Air injection system in the right place by that i mean it is easy to put the one that goes on top on the bottom and vice versa. A lot of my problems with my "Lean condition with greddy" post came from the fact that the mechanic who installed my system installed them backwards.
Old Mar 18, 2005 | 06:52 PM
Booosted's Avatar
Im going lean at high gears and high rpms, im good untill 5th gear , that could be cause of that also?
Old Mar 21, 2005 | 12:28 PM
adrian-1's Avatar
Ex- member.
Do you have a BOV installed. If so, it may need adjusting. Philodox had some stalling issues due to the BOV soft setting. post here.
Old Mar 21, 2005 | 12:54 PM
JoeMamma's Avatar
Where the air is rare
I am now. See my other thread.
Old Mar 21, 2005 | 02:47 PM
Booosted's Avatar
Yea i have a Bov its the New Rs Version, Im havin the exact same problem he was havin, i pmed him hopefully i can tighten her up some how and be good
Old Mar 21, 2005 | 03:36 PM
adrian-1's Avatar
Ex- member.
It's fairly simple to adjust. Just loosen the nut with a wrench (turn it counter clockwise). Then get the appropriate size allen wrench and turn the screw clockwise to tighten it.
I had to play around with my Type S BOV to get it at the right setting.
edit: I forgot to add that the nut needs to be tightened after you adjust the screw. It acts as a locking nut to keep the screww from moving.
Old Mar 21, 2005 | 07:23 PM
Booosted's Avatar
thanks man
ladnarf1
Apr 29, 2021 11:53 PM
Mxttz0r
Jul 5, 2019 03:19 AM
RicerX1
Jan 11, 2016 05:59 PM
Dolpho69
26
Jan 7, 2016 10:23 AM
tgaffner
Aug 20, 2015 10:55 AM
