sssshhhhhttt noise I hear
Old Mar 18, 2005 | 09:55 AM
slllygrl10's Avatar
EX-Member
I have been noticing this noise "ssshhhhtttt" underneath the car. Is this how rotary sounds like?
Old Mar 18, 2005 | 10:14 AM
guy321's Avatar
Humpin legs and takin nam
Does it sound like a grinding noise? if you press your clutch does it go away?
Old Mar 18, 2005 | 10:37 AM
Dark8's Avatar
Ride Naked!
I get a psssst kinda sound at about 3500 RPM. Was told it's normal. Is the "sshhhhtttt" sound constant or comes and goes with RPM, etc.?
Old Mar 18, 2005 | 10:50 AM
Im_DANomite's Avatar
I love GOOOLD
you dragging something??
Old Mar 18, 2005 | 11:28 AM
slllygrl10's Avatar
EX-Member
Unfortunately mine dont have a clutch hehe
Old Mar 18, 2005 | 11:29 AM
guy321's Avatar
Could it be an exhaust leak or something?
slllygrl10's Avatar
EX-Member
It comes and go and I hear it no matter what the rpm is.
Old Mar 18, 2005 | 11:30 AM
Gambit's Avatar
Screw gas mileage
If it comes and goes it's probably not normal
Old Mar 18, 2005 | 11:31 AM
slllygrl10's Avatar
EX-Member
Hmm I'm not sure. But when I start my car I smell exhaust fume or something I dont know.
Old Mar 18, 2005 | 11:32 AM
slllygrl10's Avatar
EX-Member
I was told that rotary has diff sound to them. Like you can tell if an 8 is coming cuz the way it sounds like from the outside. I hear this but very faint. I'm suspecting its my axle.
Old Mar 18, 2005 | 11:34 AM
little666devil's Avatar
I always here an SHHHHTTT sound, but it is just the intake sucking in air...unless its really not and I also have the same problem
Old Mar 18, 2005 | 11:36 AM
slllygrl10's Avatar
EX-Member
Ok good thought I was alone!
Old Mar 18, 2005 | 11:39 AM
guy321's Avatar
You've had your car for a while.. I don't think you should be smelling fumes.. have you had a catback installed recently or something?
Yes the rotary has a distinct sound.. it doesn't sound like shhhh tho,, more like arrrrrrr..
Old Mar 18, 2005 | 11:40 AM
guy321's Avatar
Your intake DOES have a problem
(sorry, just had to do it!)
Old Mar 18, 2005 | 11:42 AM
slllygrl10's Avatar
EX-Member
Not to change the subject but I was checking my oil and the dipstick had brown stuff on it. Could it be because of the cold weather?
Old Mar 18, 2005 | 11:43 AM
guy321's Avatar
Thear are a bunch of threads about milky dipstick.. I haven't read them, so I don't know what the issue is.
slllygrl10's Avatar
EX-Member
I have greddy catback. I bought my car last aug with 8k miles.
Old Mar 18, 2005 | 11:46 AM
guy321's Avatar
do you hear the noise only when the car is moving, or do you hear it on idle?
Old Mar 18, 2005 | 11:58 AM
Ha yeah it definitely does, it is basically non existant :p
Old Mar 18, 2005 | 12:05 PM
PaulieWalnuts's Avatar
Any way you can record it and post the sound file somewhere?
Old Mar 18, 2005 | 12:12 PM
slllygrl10's Avatar
EX-Member
Well there used to be this noise while on idle but since mazda had changed the spark plugs and after my car flooded the noise had went away. As far as the sssshhhhtt sound i only hear this when the car is moving.
Old Mar 18, 2005 | 12:17 PM
slllygrl10's Avatar
EX-Member
Even if I record it I dont know if you guys will hear what I'm hearing when i'm driving the car. When Im in my car you hear hhmmmm from the exhaust and plus this sssshhhhttt noise so it will be hard to record this I think.
Old Mar 18, 2005 | 12:20 PM
Go48's Avatar
Read the sticky in Issues and Problems that addresses this non-issue.
blksf8's Avatar
did you say you have an intake? My intake makes that sound where it sounds like a vacuum is on at idle. I think someone had a video clip of the K&N intake and you can hear the sound at idle.
Old Mar 18, 2005 | 12:22 PM
I took those little plastic things out of my intake (when my car ran) and it started making that "sucking in" sound, sounds sweet to me!
