Effects of Gear Grinding
Old Mar 13, 2005 | 08:59 PM
LiL BenNy's Avatar
Bubblicious? DEF.
about how many times would you have to grind your gears before everything starts to crumble... not trying this but... i've had a couple gear grinds
Old Mar 13, 2005 | 09:06 PM
Sajek's Avatar
Me too! Did it today going from 1st to 2cnd
Guess a clearcut answer doesn't exist...depends how hard, how long, etc... the grind is. I've gotten grinds that are just little blips due to reacting quickly and got hard ones (like today) when I was accelerating hard and shifted while at around 7-8k RPM in a very comitted fashion
Old Mar 15, 2005 | 01:51 PM
smrx8's Avatar
same here i wonder if iam leting it go to much always happens from 1 to 2 too.
Old Mar 15, 2005 | 05:28 PM
bmcc49er's Avatar
I have trouble with reverse and i have been driving sticks forever. Seems when the car isn't warmed up its a bitch to get it into reverse. i think its in and grind, start again. Once its warmed up it isn't a problem.
Old Mar 18, 2005 | 02:07 PM
LiL BenNy's Avatar
Bubblicious? DEF.
yeah im so scared to grind in reverse... i literally put it in, take it out 3 tiems before i feel safe reversing.. i think i need to get my gear box checked... it feels funny when i shift.... im gettting nervous about htis....
Old Mar 18, 2005 | 02:15 PM
jenkins-crew's Avatar
I grind from 1 to 2 sometimes too, hope my gear isn't getting close to gone....any tranny experts out there????
N8theGr8's Avatar
Disturbed User
If I'm not ultra-gentle on the clutch, reverse in my 8 gives me the big stink.
Old Mar 18, 2005 | 02:39 PM
SpinninAgain!'s Avatar
It's easy to grind the 1-2 shift if you:
- rush it
- pull the shift lever toward you
To avoid the 1-2 grind:
- pause for a split-second between gears
- pull the lever straight into 2nd, no sideways pressure
Reverse is tough too, very touchy until you get used to it. Take it very slow and easy until you get happy with the car.
Old Mar 18, 2005 | 03:29 PM
guy321's Avatar
Humpin legs and takin nam
an occasional grind is OK, if you have constant grinding there could be somethign wrong with your tranny. when you grind it is not actually the gears grinding but the dog teeth not meshing. Still not good to do alot, but it's not gear teath that you normally would think of.
But i know nothing about trannys.
Old Mar 31, 2005 | 11:17 AM
crosswound's Avatar
get it looked at they took mine apart and it stated on my receipt transmission failure and they replaced a bunch of things i had the hard shifting 1st into 2nd when i first had the car and it grinded like a bastard.
so i did the things he suggested and it went away then i had my hard shifting into 4th and also reverse didn't like me very much i finally got annoyed brought it in and told them what was going on.
they tore apart the tranny and had to replace a bunch of parts.
Old Mar 31, 2005 | 11:54 AM
was it done under warranty?
Old Mar 31, 2005 | 12:36 PM
adrian-1's Avatar
Ex- member.
Check this thread if your having 1st to 2nd gear grinding, no shift, or stuck in gear.
Old Mar 31, 2005 | 02:50 PM
crosswound's Avatar
well so far its been covered under warranty its back in the shop because my 6th gear keeps popping out into neutral at highway speeds and i can always smell this oil or gas smell all the time too.
i have some luck this time the last incident where my clutch blew they blamed it partially on me.
Old Mar 31, 2005 | 03:10 PM
But they replaced your clutch under warranty? How did you get them to do that?
Old Mar 31, 2005 | 03:31 PM
Shamblerock's Avatar
When its not warmed up its just a bitch, period. I have adopted implementing a slight pause in between shifting gears. Seems to help but it suck to always do that. What can you do? The dealer claims they haven't found anything wrong with it. When it gets colder next fall I'll see to it that I leave it overnight at the dealership and show them first hand the problem.
Old Apr 2, 2005 | 11:14 AM
crosswound's Avatar
my clutch wasn't covered all under warranty they supposedly made me pay for labor but people are telling me labor is free if you get the part from the dealer i don't know.
but so far with the tranny problem its been covered under warranty, thank god!
i just called today and they said visually nothing looks wrong with 6th gear. whats nice is before i brought it in for my 1-2 and 4th problems 6th was a smooth gear.
now it doesn't work is what gets me so they are just going to order a new 6th gear looks like i won't have the car for a week again and drive around in a rental.
Old Apr 2, 2005 | 11:27 AM
army_rx8's Avatar
X-Sapper
awe you beat me too it....but you are correct it is the dog collar that makes the grinding sound...b/c the gears are always moving and ingaged with eachother......only the dog collar moves to engage the driveshaft with whichever gear you want your baby to be in.:D
Old Apr 5, 2005 | 07:46 AM
KYRX8's Avatar
so, if i read this correctyl, i can replace my 2nd gear shift fork and the grinding will be gone?
If so, how hard is it to replace that fork? Im not going to do it myself but does it call for a rebuild or is it something they can do when installing a new clutch and flywheel?
Old Apr 8, 2005 | 01:00 PM
crosswound's Avatar
got my car back shifts better than when i first got it although i still miss reverse sometimes but thats because i'm a idiot.
Old Apr 8, 2005 | 02:42 PM
airboss's Avatar
The reason for your reverse gear problem is that you have no true reverse gear on the RX8 six speed. But rather, you have an "idler" gear that tries to engage first, but with no syncro ring. So if if does not engage, put your chutch in, place shifter in nuetral, let out the clutch and do it over again. Make sure that you are at idle, and not moving.
Old Apr 8, 2005 | 02:48 PM
airboss's Avatar
Red face
You should do 2 things.... 1) Install synthetic oil in your gearbox and rear end, (Check owners manual for spec.) 2) Think as you shift. Make sure that your clutch peddle is fully depressed, then shift. All your problems should go away!!
Old Apr 8, 2005 | 03:27 PM
Already out Synthetic oil in the tranny about a month ago. Same ****, if not worse. I am actually thinking that they may have not topped it up. I think some friggin arms between 1st and 2nd is out of place or need to be tighten or something. Its happening less these days because its warming up in Toronto.
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
