kaaz lsd
Old Mar 9, 2005 | 07:07 PM
upgradesRX's Avatar
kaaz lsd
im getting ready to order a kaaz lsd for my 8 and was wondering if anyone has installed one or had one installed and there impressions.
Old Mar 9, 2005 | 07:25 PM
army_rx8's Avatar
X-Sapper
you got a site..i've never heard of this for the 8 all i knwo of is the mazdaspeed 2 way 3-way adjustable..and teh re-amemiya lsd's for the 8. put up a web site please:D
Old Mar 10, 2005 | 02:18 AM
truemagellen's Avatar
Attracts tree branches
interesting
really few lsd swaps have been made on the forum...it is very rare and only tracked 8s have had it done
hmm Lschaivo want to chime in on this one?
Old Mar 10, 2005 | 07:54 AM
cretinx's Avatar
did you break your stock one?
Old Mar 10, 2005 | 09:29 AM
upgradesRX's Avatar
http://www.kaazusa.com/pricelist.xls
my car did not come with traction control, so theres not much of a diff in it. im installing a exedy hyper single clutch and flywheel, so i figured i would do the diff at the same time
Old Mar 10, 2005 | 12:20 PM
Cam's Avatar
Cam
this space for rent
I thought I read somewhere that the re-amemiya lsd is made by Kaaz?
Cusco makes a LSD for the 8, based on Upgrade motorings site. I thought Kaaz did as well, but the their site doesnt show a listing.
http://www.upgrademotoring.com/suspe.../LSD/mazda.htm
Old Mar 10, 2005 | 02:30 PM
upgradesRX's Avatar
ive ordered several things from naps usa (the distributor for cusco) and they've never mentioned a lsd for the 8 when i ask all the available parts for it, but i will check with them agian. kaaz shows on their price list rx7/8 which i think means it works for the 7 as well as the 8. im callin them later today to find out for sure
Old Mar 10, 2005 | 02:34 PM
army_rx8's Avatar
X-Sapper
ouch cusco is about 1k -1.2k ouch in the poket book..but i guess that isn't too bad..teh re-amemiya one is abotu that much. i think the ms 2 way is like 890. a lill better on the poket book:D (there selective 3 setting adjutable l.s.d. is like 1300 or something). well it's good to know we have a few options
Old Mar 10, 2005 | 02:49 PM
Cam's Avatar
Cam
this space for rent
I tried researching my question but was not able to find an answer.. Regarding the MS Selective 3 setting LSD..what exactly does that mean?
Old Mar 10, 2005 | 03:32 PM
upgradesRX's Avatar
you were right on cusco makin a diff for the 8, its a 1.5way but can be configured to be a 2way if your serious about track or drifting. the diff is the same one for the rx7 so i would say pretty much any diff you find for a 7 (which im sure theres a ton of)will work for the 8.
Old Mar 10, 2005 | 05:43 PM
army_rx8's Avatar
X-Sapper
i take it to mean that you can select it to be a 1-way, 1.5 way, or a 2 way l.s.d. anyone else have any thoughts? i e-mailed mazdaspeed..but it might take a few years to hear back from them.
Old Mar 10, 2005 | 06:23 PM
upgradesRX's Avatar
i would say that your right army, but i doubt you really select it to change, i would think that you have to physical change the diff by adding or moving parts. an electronic diff like a sti's for example would prove to be quite a task to install.
Old Mar 10, 2005 | 07:03 PM
rotaryred's Avatar
Your car doesnt have traction control so it doesnt have much of a diff anyways? Every rx-8 6spd has the same differential, I hope your not getting this for traction issues, because the lsd will still break loose just as easily as the stock one.
Old Mar 10, 2005 | 09:51 PM
army_rx8's Avatar
X-Sapper
HEHE yea i didn't mean to sound as if there is a button you push to change teh settings...you most likly have to taek teh damn thing apart..or get down there adn select it with some kinda' tool...:D
Old Mar 10, 2005 | 09:55 PM
Cam's Avatar
Cam
this space for rent
Thanks army. That makes too much sense, no wonder I couldnt find anything. I was over analysing it.
Old Mar 10, 2005 | 09:58 PM
army_rx8's Avatar
X-Sapper
:D no problem i would just go with a ms 2 way...haha but good luck trying to get any info from them on how much power it can take befor it has issues...well not liek we are gonna see any 500whp monster 8's any time soon. haha i'd be happy with 350 myself and i'm sure it can take that.
Old Mar 11, 2005 | 04:36 PM
upgradesRX's Avatar
to answer rotaryred i want it to break loose but i want both tires spinning instead of one. and since the lsd is the same for the 8 as the 7 dont think theres much to worry about in breaking one.
Old Mar 12, 2005 | 10:04 AM
army_rx8's Avatar
X-Sapper
only have to worry about braeking it if you use it with more power or in ways it wasn't meant to be used:D i.e. use it in a 900 hp monster when it's only good up to 350 (ok that was unrealistc in teh 8..hah a900...that'll be a while off)....or drive it like you stole it 24/7. i'm sure it'll get some crazy wear and tear then.
Old Mar 12, 2005 | 01:32 PM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
Acosta Racing already hit 900hp :D And that was a while ago.
Old Mar 12, 2005 | 01:40 PM
army_rx8's Avatar
X-Sapper
haha yea...and has anyone seen their 900 hp car (which wasn't to the wheel by the way)..i've never seen a dyno..nor a time slip..nor hear of it actually putting all of that to the ground. soooo until i do..it' sjust a dream in my book. besides they changed out the engine and the whole drivetrain.....lsd, tranny, lsd, engine....everything was different..only the car body was an rx-8 basicly. woudl be nice if it worked. but last tiem i checked they've been tryign to sell tha tthing off and on since they anounced it....still no takers:p
Old Mar 19, 2005 | 01:42 PM
lafrad's Avatar
Wanna-be RX Owner.
I may be new to RWD Performance cars, but for the year that I have had my RX8, any time I break the tires loose, I get both tires going. If I do a brake stand, I end up with 2 VERY even strips of rubber on the pavement. I realize that a Torsen differential that all the 6 speed 8's come with doesn't guarentee one spin, one wont, but so far, I have found very few (read, not one) situation where one wheel was spinning when the other wasn't.
Even with one tire on snow and one on dry, I was able to accelerate pretty well...
Yes, i have traction control, but I turn it off before I do anything crazy :-P
Old Mar 20, 2005 | 03:19 PM
Gord96BRG's Avatar
The standard RX-8 differential is a Torsen limited slip with clutch pre-load - whether you have traction control or not. Unless you can explain exactly what the advantages will be of a Kaaz aftermarket diff vs. the Torsen preload LSD already installed in your car, you will be wasting your money.
Understand what you've already got before you waste money replacing it with something that will behave exactly the same!!!
Regards,
Gordon
Rx8Mango
Canada Forum
Aug 17, 2015 12:20 PM
SilverRX8
Aug 22, 2006 06:09 PM
scsi
19
Apr 26, 2006 11:49 PM
Vagus
Far East/Asia
13
Apr 29, 2004 04:14 PM
