Got lows, almost got highs, must be Bose
Old Mar 8, 2005 | 09:24 PM
modena's Avatar
Modena
Following an older tread:
https://www.rx8club.com/showthread.p...er+replacement
I orderered the Image Dynamics NX30s, they should be delivered by Thursday....
They are supposed to be a replacement tweeter for the Bose.
Parts are ready to be installed; pictures of the finished install will follow when done.
For those who have installed them, did you use the flush swivel mount that comes with said tweeters?
(Don’t mind to cut the "sail" panel to fit them)
Attached Thumbnails Got lows, almost got highs, must be Bose-mazda_rx8-62.jpg   Got lows, almost got highs, must be Bose-mazda_rx8-63.jpg   Got lows, almost got highs, must be Bose-mazda_rx8-64.jpg
Old Mar 8, 2005 | 10:03 PM
4080's Avatar
I thought it was:
No highs, no lows, must be BOSE.
Old Mar 9, 2005 | 07:59 AM
modena's Avatar
Modena
Originally Posted by 4080
I thought it was:
Got the lows from you!
(A box you made....)
Love it buy the way!
Old Mar 10, 2005 | 05:06 PM
modena's Avatar
Modena
There in...
Used the swivel mount that came with them and need to play around with the angels of the tweeters.
Honestly, highs are what I was missing after 4080's sub-box
And that is fixed for now.
Attached Thumbnails Got lows, almost got highs, must be Bose-mazda_rx8-65-medium-.jpg   Got lows, almost got highs, must be Bose-mazda_rx8-66-medium-.jpg   Got lows, almost got highs, must be Bose-mazda_rx8-67-medium-.jpg
Old Mar 10, 2005 | 05:17 PM
TRU681's Avatar
Looks good!How does those ID componenets sound?
Old Mar 10, 2005 | 05:30 PM
Shocka's Avatar
WHAT.... YEAH... OK!
the install looks great.. did you have to do any cutting to fit them?
Old Mar 10, 2005 | 07:10 PM
modena's Avatar
Modena
Sound is completely different, meaning you can actually hear high frequencies.
If pointed at you it almost hurts!
Yes some cutting was needed, Bose grill is gone as is the mount that kept the Bose in place.
(For 119$ it is definitely worth it, If you have the Bose and don't want to rip it out)
Old Mar 11, 2005 | 09:48 AM
StphNieuw's Avatar
Did you get a cross over for this or is it just a repl?cement type job.
Old Mar 11, 2005 | 11:08 AM
modena's Avatar
Modena
Tweeters come with no x over, used the Bose one and works great.
(It’s an inline x over)
Old Mar 11, 2005 | 12:22 PM
StphNieuw's Avatar
Does anyone know how the base audio system's tweeter are hooked up?
Old Mar 11, 2005 | 01:14 PM
Tamas's Avatar
Registered Lunatic
Yes - they don't have a crossover, just a capacitor in-line.
Old Mar 11, 2005 | 05:00 PM
StphNieuw's Avatar
So could you just replace the stock tweeters with these or would it make more sense to get a cross over
Old Mar 11, 2005 | 05:39 PM
modena's Avatar
Modena
It makes sense on the Bose,
Weird speaker sizes ext., as for the none Bose I personally don't know.
(I thing yes, but could be wrong)
Old Mar 11, 2005 | 08:41 PM
Tamas's Avatar
Registered Lunatic
If you want to improve the base stereo, it is not worth to only replace the tweeters. The stock front 6x8 speakers are crap. You'd be much better off with installing a good set of component speakers.
Don't waste your time to do the tweeters only. If you want to do the least amount of work, get a set of 6x8 component speakers such as the Infinity 6800cs or there is one by Rockford as well - probably other manufacturers too. Get a set that is very effective and with the 6x8 you don't even need to create an adapter plate, it's direct drop-in.
Old Mar 11, 2005 | 09:14 PM
StphNieuw's Avatar
I'm planning on replacing the stock speakers anyway, just curious if I can also replace the tweeter as the seem to a be a pretty good match
Old Mar 12, 2005 | 01:27 AM
Tamas's Avatar
Registered Lunatic
Sure you can. I did the same in my car too and I had the base stereo as well.
Old Mar 12, 2005 | 08:42 AM
modena's Avatar
Modena
Image Dynamics has a component system as well that includes the Tweeters I used,
(It will not be a direct drop in, but with some handwork it should fit)
http://www.cardomain.com/shoplist~b~...peaker+Systems
Old Apr 29, 2005 | 11:26 PM
irfan's Avatar
ElusiveSasquatch
any one that has the infinity tweeters (1") .. ae you able to to just pop off the grill so you can still mount it and make it look stock behind the bose grill? i want to upgrade these pretty badly, the 2 10's in the trunk drown out any highs. i dont want it to look custom tho.
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
stickmantijuana
Sep 4, 2015 10:31 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
