difficulty starting my 05.
Old Mar 6, 2005 | 08:17 PM
wpb599's Avatar
I have searched and found that octane might be a reason, but I was wondering if anyone else has to crank the engine over more than a couple of seconds to get it to start? This happens all the time for me. Key to acc position, wait for lights and whistles to stop, clutch all the way down and turn key. Takes a minimum of a couple of seconds before it catches. Most other cars I've owned catch quicker. Should I be concerned about this. Any responses would be greatly appreciated.
Old Mar 6, 2005 | 08:23 PM
rx8pilot's Avatar
Watch your six
it sucks..but it's just a common thing on the eight.. i know how you feel though.i wish mine would start a little more positively too.
Old Mar 6, 2005 | 08:24 PM
irish8's Avatar
Get in ma belly!!
Nope. Normal. Don't worry about it. Also, don't forget to let her heat up before spirited driving. And, before shutting her down, rev the engine to 3k rpm's. This will burn up any oil still in the chamber.
- Irish
Old Mar 6, 2005 | 08:28 PM
wpb599's Avatar
Thanks for the quick replies. Glad to hear that I'm not the only one with the problem. I didn't realize that I had to rev to 3000 rpm before shut down. I'll definitely add that to my routine.
Once again, thanks.
Old Mar 6, 2005 | 08:31 PM
irish8's Avatar
Get in ma belly!!
wpb599...it's not a problem. It's normal for the rotary engine. I actually love the way the rotary fires up!!
Enjoy!!
- Irish
Old Mar 6, 2005 | 08:33 PM
TheDosDog's Avatar
Recovered Modaholic
A tech told me rotaries take longer to "catch" because they can't develop significant compression until oil reaches the apex seals. I would not call it a problem, just something unique to the rotary.
Old Mar 6, 2005 | 08:38 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
It's not a problem until it doesn't start, right?
Old Mar 6, 2005 | 09:15 PM
rx8pilot's Avatar
Watch your six
Once again, thanks.
Unnecessary.... don't need to rev to 3000 before you shut down. just make sure your engine is good and warmed up before you shut down.. that's all.
Old Mar 6, 2005 | 09:21 PM
m82492's Avatar
My 05 does the same thing. It's completely normal.
Old Mar 6, 2005 | 09:41 PM
rx8cited's Avatar
Senior Member
I agree 100%. I don't rev on shutdown if the engine is warm and I've never flooded with 16 k miles.
Old Mar 6, 2005 | 09:43 PM
rx8cited's Avatar
Senior Member
Originally Posted by irish8
.......And, before shutting her down, rev the engine to 3k rpm's. This will burn up any oil still in the chamber. ......
Did you mean to say "burn up any fuel still in the chamber"?
Old Mar 6, 2005 | 09:55 PM
CERAMICSEAL's Avatar
I would imagine that on the latest flash (Computer update) there probaly is a safer (Lesser) amount of fuel available at crank up which would explain the longer crank time. If this is the case; which I'm reasonably sure of, then it's great and should have been this way from the start. We used to modify the fuel pumps of the 86 to 91 7s to prevent fuel from being available at the rail under pressure until start up for this same purpose.
Old Mar 6, 2005 | 11:49 PM
E-brake's Avatar
Enjoy!!
- Irish
Exactly. I LOVE the way rotarys fire up. It's like a jet :D
Old Mar 8, 2005 | 07:13 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
I agree...I don't do that and I've had no issues. In the morning I crank her up, wait till the rpm's hit's 1.5K-1.4K...and then take off. You will not warm up the engine any faster than actually driving the car. Now, don't rev high while cold (I keep it under 4K while cold) but it only takes me .5-1.5 miles for the little rotary to warm up.
As many have told you: DON'T TURN IT OFF COLD!!!!
Old Mar 8, 2005 | 11:28 PM
CASANOVA's Avatar
word....word....
mine takes awhile to start also,but it doesn't seem to be a problem.I learned the hard way, let it warm up and don't turn it off cold.
Old Mar 9, 2005 | 02:19 PM
slllygrl10's Avatar
EX-Member
Since my car flooded last Jan 05, I stopped the warmup procedure and since then I havent had any problem flooding. I'm sick of it.
Old Mar 10, 2005 | 06:17 AM
rx8cited's Avatar
Senior Member
Sick of what?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
poppinparker
Aug 10, 2015 09:20 AM
