Stupid, stupid question
Old Mar 6, 2005 | 08:29 AM
bmcc49er's Avatar
I have never in my life bought aftermarket wheels. What constitutes having to change your tire size. In other words I have oem size tires on. I must have 18x8 wheels, but I am thinking the offset does not affect the tire size? Or the other way around? I am trying to find a offset as close to the stock 50 as i can but finding it difficult.
Old Mar 6, 2005 | 11:23 AM
epitrochoid's Avatar
Riot Controller
offset has little to do with tire size...
you only need to go to wider tires if you get a wider wheels, or 19" tires for a 19" wheel etc. offset only comes into play with very wide setups that risk rubbing on the inside of outside
Old Mar 6, 2005 | 08:39 PM
rx8cited's Avatar
Senior Member
Not sure if this helps: http://www.tirerack.com/wheels/tech/offset.jsp
They say:
"If the offset of the wheel is not correct for the car, the handling can be adversely affected."
Old Mar 6, 2005 | 08:57 PM
bmcc49er's Avatar
I cannot find a 50 offset wheel anywhere. Must be alot of people on here running different offsets on their custom rims.
Old Mar 6, 2005 | 09:08 PM
Riot Controller
you want to get as close as possible...at some point, you will rub on the fender if you do not go with a lower offset. unfortunately not many RWD imports like ours have such high offset, so the choices are slim. there's a good selection of 40-48 offset rims, and that should work ok.
just do some looking around here and see what offsets others are running
Old Mar 6, 2005 | 09:24 PM
bmcc49er's Avatar
Waiting on a reply from the company on the specs of these. Damn, I hope they are close. I personally like one of these for my green 8.
Attached Thumbnails Stupid, stupid question-blade_250.jpg   Stupid, stupid question-rs_akunin.jpg
jer2911
Sep 29, 2015 06:37 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Austin22
Sep 23, 2015 04:46 PM
Wurromurro
Sep 20, 2015 05:02 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
