Turbo and emissions
Old Feb 23, 2005 | 08:59 PM
NoTears316's Avatar
Shock and Awe
Question Turbo and emissions
I have been getting a lot of conflicting answers about this question. I have read from a number of posts on this board that the GReddy turbo will not pass emmisions. I was just told today from a very trusted source that the GReddy turbo is emmisions friendly. Anyone have any hard facts on what the deal is with emmisions and the GReddy turbo?
Old Feb 23, 2005 | 09:02 PM
expo1's Avatar
He's as bad as Can
http://www.mazdatrix.com/8turbo.htm
"Please be aware these kits are NOT emissions legal, and DO void your car warranty from Mazda"
Also the Instructions state the same thing on the last page. They would sell more if it was CARB legal so you would think they would be working on one. LINK
Old Feb 23, 2005 | 10:12 PM
Fanman's Avatar
In the recent SCC (Sport Conpact Car) magazine they had a segment on superchargers. One of the positive points they pointed out was that SC's will be easier to get CARB certified because the turbos will take longer to warm up & light off the cat. In that first minute or so it gives off like 90% of the pollutants that the car will put out on a trip. So the turbo will have great difficulty getting CARB certified. Take it for waht it is worth.
Old Feb 24, 2005 | 12:30 PM
NoTears316's Avatar
Shock and Awe
Thanks guys.
Old Feb 24, 2005 | 12:38 PM
expo1's Avatar
He's as bad as Can
For some people this issue doesn't matter. In New Jersey you do not have to get a NEW car inspected till it's 4 years old. By that time many owners will be onto their next car. So if you have to money to fix it yourself then why not enjoy the Turbo.
Old Feb 24, 2005 | 12:40 PM
8is>enuff's Avatar
Bland
I actually passed emissions without a cat on my '97 GSX (turbo) in '99. Since turbos generate a lot of heat, I was told to rev the car up on the way to inspection and get the pipes nice and hot. Hot enough to burn off the particles on the way out of the exhaust. I don't know if it's true or not, or whether it applies to 8's with the Greddy turbo or not, but I passed.
Oh yeah, I was running about 16-17lbs of boost, so it was probably a lot hotter.
Old Feb 24, 2005 | 12:51 PM
ddub's Avatar
always preoccupied.
Yah my friend had a 1st gen GSX and did that too, passed with no cat. From what I understand the eclipse's are kinda special, meaning passing emissions with no cat is very rare and very hard to do.
Also, a rotary puts out a lot more emissions than a piston, even though the rx8 has side exhaust ports now instead of peripheral exhaust ports (which help with emissions) I still REALLY doubt it'd even come close to passing emissions with no cat.
For reference, my 2nd gen rx7 had no cat when I bought it, got it tested at a nearby Shell station before I knew this and it blew 2015 HC at cruise and 1876 HC at idle. Take it for what its worth to you
Old Feb 24, 2005 | 01:02 PM
expo1's Avatar
He's as bad as Can
Don’t know if that would work now in Jersey. First off if you use the state run inspection station you have to get out of your car. Also the way they do the emissions test now is they place the drive wheels on rollers and get the car to over 15 MPH (not sure on the speed) they do not test an idling car anymore.
Old Feb 24, 2005 | 01:32 PM
Red Devil's Avatar
I think they put the cars on rollers here in Illinois also. Never had to do any inspection in Florida.
Since right now there is no CARB certification for any of the forced induction options, they right now are teasers for people like me that both intend on keeping the car for an undetermined length and need to pass emissions.
Old Feb 24, 2005 | 01:39 PM
ddub's Avatar
always preoccupied.
Just put the turbo and stuff on then take it off for emissions, and put it back on afterwards. Problem solved.
Old Feb 24, 2005 | 01:44 PM
RX-8fan01's Avatar
in maryland ....... the just plug it into the ECU .... and if there is a code they will run it on the treadmill ... so i hope i should be good ....Most the people at my emsission station they dont care to much about it .....
Shane
Old Feb 24, 2005 | 03:37 PM
Red Devil's Avatar
Very expensive and/or time consuming to install and remove for every emissions test. Though at two year intervals I suppose it is an option.
Old Feb 24, 2005 | 03:41 PM
ddub's Avatar
always preoccupied.
You just have to weigh your options. For my 2nd gen rx7 I do an exhaust swap and put in my "custom" emissions equipment with custom routing when it comes time for the test. Only had to do this once so far, took half a day, took the test, came home spent the rest of the day swapping back. Didn't bother me much.
Old Feb 24, 2005 | 04:10 PM
Red Devil's Avatar
Hmmm...if only I can convince my sister in Miami Beach to let me register my car under her. Don't think they have emissions in her county.
Old Feb 25, 2005 | 08:21 AM
Virgil's Avatar
They put it on a dyno of sorts in Washington state to, takeing it up to highway speeds and then bringing it back down.
Old Feb 25, 2005 | 09:32 AM
ddub's Avatar
always preoccupied.
Not highway speeds, only 20mph.
Old Feb 28, 2005 | 01:04 PM
kwescott's Avatar
One ball, corner pocket
I guess it depends on your state, and their standards for testing. California is very strict on their testing standards. From what I've been (told), the GReddy turbo kit wouldn't pass an emissions test on several different standards, one being the visual inspection portion of the test here. Basically, the open air filament would be the initial indicator to the tester of modification to the vehicle. Cold air, and short ram intakes are not approved for California. I have decided against going with the turbo at this point because I definately don't want the hassle of taking things off and on..maybe there will be more options in the near future for me here in California.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
