guitarjunkie28
02-21-2005, 01:22 PM
i haven't seen any afr's and timing numbers for the turbo kits yet.
the motor is 10:1 compression- which would make me want to pull a bunch of timing out (compared tot he same setup on an rx7 motor),
but
it's got zero overlap, so with a cleaner intake charge, you should be able to run more timing...
can anyone give me a rundown of the afr's and timing under boost?
thanks
but
thanks
