Nology Spark Plug Wires Crap
Old Feb 20, 2005 | 07:45 PM
superhuff's Avatar
I put these crap wires on my car and it made my check engine light come on because its causing my cylinder to misfire. Alot of people are having this problem. Anyways, im trying to figure out what way to put the only ones back on. 2 of the wires are color coated but i cant figure out if they go to intake or exhaust slot. Anyone able to help me out? There are 2 upper spark plug holes and 2 low that come off the distributer. Let me know if you know anything please.
Old Feb 20, 2005 | 08:30 PM
Fanman's Avatar
Yeah, unfortunately this is pretty common. A few posters actually had their spark plugs melted through when they put the Nology wires on.
Old Feb 20, 2005 | 08:35 PM
expo1's Avatar
He's as bad as Can
I think you should avoid any more mods till you either read up more on your car or get a shop manual. RX-8’s do not have cylinders or a distributor. Anyway those wires are not cheap so the vendor should be able to help. They also appear to be the same color http://shop.store.yahoo.com/hopup1/nohospplwima.html
So I don’t get the color-coated part of your question. I would just put back on the OEM wires till you get this sorted out. I am taking a guess that you need to know which wires goes to which plugs, I am attaching a pic.
Old Feb 20, 2005 | 09:53 PM
davefzr's Avatar
I had my plugs melted. They were crap. My engine would give out after 8,000... it was a terrible experience.
Old Feb 20, 2005 | 10:35 PM
black-rx8-msbodykit's Avatar
lol, that sucks. i put on my nology wire in my school, i used a lift so it's easy to work up and down. I did 1 wire at once, so it won't get all **** up.
Old Feb 22, 2005 | 12:43 AM
intakedrotary's Avatar
fixed my problem
I fixed a misfire problem by installing these plug wires and denso racing plugs. So my rx8 must be a goofy one! LOL
Old Feb 22, 2005 | 01:10 AM
StealthTL's Avatar
Metatron
Plugage.....
...and to answer your plug problem....
There are four coil packs, numbered from front to back -
first goes to front, bottom (leading)
second to front top (trailing)
third to rear rotor, bottom,
and fourth to rear rotor top.
S :D
Old Feb 22, 2005 | 12:42 PM
galleychief's Avatar
Unbalanced & Unmedicated
So what's the consensus?
1. Stock plug wires are good, don't change them.
2. Aftermarket wires are a good idea, as long as they are not the Nology brand?
Old Feb 22, 2005 | 12:44 PM
davefzr's Avatar
Yeah.. I would have to agree. People tend to love Racing Beat's wires and have no issues with them.
Old Feb 22, 2005 | 09:37 PM
bureau13's Avatar
I'm sure there are a number of aftermarket wires that are good, maybe "better" than stock in some way...but unless your stock wires go bad, is there really any reason to upgrade them? In more-or-less new form, are the stock wires really any less good than they need to be? In my opinion no, but I'm curious what others think.
jds
Old Feb 23, 2005 | 01:50 AM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
why did they melt?
Old Feb 23, 2005 | 02:42 PM
Gord96BRG's Avatar
This forum has been around long enough to start serving as a good information and reference source. I highly recommend searching here for previous threads discussing parts or components that you're considering purchasing or installing.
Try a search on 'Nology' - you'll find a bunch of threads, going back over a year. Much discussion, most of which would have convinced you in advance to not waste your money on them.
Regards,
Gordon
Old Feb 23, 2005 | 03:13 PM
Richard Paul's Avatar
13 I think I address this in my "understanding heat range" thread
RevMeHarder
Jun 1, 2026 02:30 PM
TeslaMSI
Dec 10, 2015 01:10 AM
DVerdeyen
Sep 13, 2015 11:19 AM
iwannarun
Sep 6, 2015 01:37 PM
