Dose this work???
Old Feb 16, 2005 | 04:36 PM
finizzle's Avatar
Dose this work???
i was wondering if this product really helps and if so how.
thanks
http://cgi.ebay.com/ebaymotors/ws/eB...category=33577
Old Feb 16, 2005 | 04:39 PM
xdrian's Avatar
Banana Yellow :P
i asked the same question, but not that i know of that it works.
Regular grounding kit works best.
Old Feb 16, 2005 | 05:14 PM
Sociopath's Avatar
SocioPath
Correct me if I'm wrong, but I believe this is NOT a genuine Mazdaspeed component; I think its just a regular component made by some company overseas, with a imitation Mazdaspeed badge, trying to pass off as a genuine component. Don't Buy It, Beware! I haven't heard of anyone using it, or if any of the stated performance improvements could be proven.
In general I would suggest you to stay off on buying parts from eBay; not worth the risk. Like Xdrian said, use the regular grounding kit, which consists of 4-6 grounding wires.
Old Feb 16, 2005 | 06:20 PM
cretinx's Avatar
They make the car start up faster, make the stereo louder, and give you brighter lights - they can also offset underdriving slightly.
Old Feb 16, 2005 | 06:41 PM
expo1's Avatar
He's as bad as Can
Correct me if I'm wrong but once the car is running what does the battery do except get charged back by the alternator??
"DM VOLTAGE STABILIZER System is to stabilize the flow of the voltage from the battery. By stabilizing the voltage from the battery, the load on the battery is reduced, resulting in increasing engine performance and electrical equipment."
That’s the reason cars have voltage regulator because the alternator makes more than enough voltage to run things?
Old Feb 16, 2005 | 06:56 PM
Spin9k's Avatar
Momentum Keeps Me Going
Sounds like an expensive capacitor to minimize current spikes and surges, wooppie ding
Old Feb 16, 2005 | 11:16 PM
finizzle's Avatar
any suggestion on a good grounding kit
Old Feb 17, 2005 | 06:37 AM
expo1's Avatar
He's as bad as Can
I have this one http://www.groundfusion.com/ProductDetail.php?gkid=18
The difference between a good and bad one is in how hard it it to install it. This MOD adds ZERO HP.
Old Feb 18, 2005 | 06:43 PM
mikefrombarrie's Avatar
What do you mean by "offset underdriving slightly"?
Old Feb 18, 2005 | 10:48 PM
David_M's Avatar
the alternator doesn't run the electrical system on your car the battery does. The alternator doesn't produce a constant output because it is tied to the engine speed, so it charges the battery which puts out a relatively constant voltage. Note that I said relatively constant. The actual voltage output varies slightly depending on demand. As an example, if youv'e ever had a car with a powerful enough stereo system you can actually watch the headlights dim every time the bass hits.
Old Feb 19, 2005 | 12:20 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
I am inclined to disagree. If the battery ran the entire system, then unpluging the battery during the cars operation should result in an immediate dead engine, however this is not true. The car will continue to run via the alternator output voltage. The only time the battery is used is if the draw become greater than the output of the alternator. (Such as on startup) The alternator voltage varies, but not much -/+2 Volts at most.
Old Feb 19, 2005 | 04:28 PM
David_M's Avatar
I may have oversimplified. The electrical system in your car is routed through the battery to ensure a constant voltage output. The alternator alone will not allow normal operation of the vehicle because as soon as demand becomes greater than output ( such as turning the headlights on while idling ) the car will shut off. Older cars generally have lower power requirements and a less critical need for a stable power output while newer cars ,due to computers and such, are much more sensitive to voltage fluctuations. What this means in specific reference to the RX is that if voltage drops too low the car will shut off because the computer has shut down taking with it control of the fuel and spark. On pre computer cars a voltage drop that effected the ignition system would simply not fire the spark plugs, if the interuption was brief enough all you would notice would be a stumble in the engine.
Modern electronics don't need perfect power delivery, however the more constant the power delivery the better that they work. So the little box that started this thread is supposse to guard against inefficiency by quieting spikes in demand on the electrical system.
TeslaMSI
Dec 10, 2015 01:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
mattymack
Sep 6, 2015 10:33 PM
ion_four
Jul 30, 2015 09:48 PM
