Clutch Stomp
Old Feb 14, 2005 | 10:49 PM
Jaisin's Avatar
Jason
Question Clutch Stomp
Is it okay to stomp the clutch or push it in really fast? I can shift faster if I can feel the clutch hit the floor because I know that it is safe to shift without grinding. I know you are not supposed to drop the clutch, but is pushing it in fast okay? It makes the weight transfer less also because I can get back on the gas quicker. It seems like I can shift in 1 second or less. 1.5 seconds max.
Old Feb 14, 2005 | 10:54 PM
Rhawb's Avatar
Has the whole shit.
I don't think stompping on it really makes a difference, just don't drop it real fast afterwards. I've found the easiest way to be smooth is to not try and force anything though, just do everything with a smooth, natural motion, and it all works out. Now, if you actively try to do this, it usually ends up being choppier because you sort of tend to force youself to do "natural" motions, so just work on finding a nice, natural series of motions to shift (even if the car doesn't shift entirely smooth) and it'll become butter in no time.
Oh, and I tend to just make a habit of pressing the clutch all the way down every time. If you're really extending to do so (or all over it) you're not sitting quite in the right position. You should just be able to extend your foot comfortably before you hit the end of the clutch. Finding just the right spot will really help your smoothness as well.
Old Feb 14, 2005 | 10:58 PM
Jaisin's Avatar
Jason
K, Thanks. I sit 8 inches from the wheel and I sit straight up also. I am like 5'3" so I have to sit really close. I can manipulate the clutch pretty well.
Im_DANomite's Avatar
I love GOOOLD
i just pictured some kid stomping the **** outta of his pedals...hilarious. how many people out there bought their RX8 as their first manual????? i don't understand this...
Old Feb 14, 2005 | 11:47 PM
Captain Amazing's Avatar
:o But I learned it in under an hour and was able to go on real roads.
Old Feb 14, 2005 | 11:57 PM
Jaisin's Avatar
Jason
What is speed shifting or power shifting? I don't understand how it works. I've tried what I think it is, but it didn't make sense and I don't see why anyone would do it. I kept the gas pedal depressed while I shifted, but that caused the tach to beep and the fuel to cut off? Seems like its unneccessary/
Old Feb 15, 2005 | 12:03 AM
Rhawb's Avatar
Has the whole shit.
Yeah, that kind of stuff (clutchless shifting, power shifting, etc.) is probably stuff you don't want to mess with unless you have an instructor right there. You can ravage your tranny pretty badly with things like that. If you really want to learn a useful technique, learn heel-toe downshifting. That's relatively safe...just don't practice unless you have some room to screw up, because it's easy to get crossed up when you're learning it.
Easiest way to learn heel-toe is to first learn to downshift with rev-matching (blip the throttle about 1000-1500rpm as you move to the next lowest gear and let the clutch out), then add braking and the heel-toe motion once you're proficient with rev-matching.
Old Feb 15, 2005 | 12:06 AM
Fanman's Avatar
That's pretty much what it is. When you do not release the accelerator when you change gears. You do not get as much of the lag as when you let go of the accelerator & have to push it again. You notice that in regular shifting the revs drop, and you have to rev it again. With speed shifting the drop in revs is less & the time it takes to build revs decreases. You have to be very good with shifting for it to make much difference. Like you said, most people shift when they are at redline, and can't go through the multiple gears fast enough anyways. The key is not to let the engine get to the fuel cut but to shift right before it.
Old Feb 15, 2005 | 06:59 AM
StewC625's Avatar
Insanely Yellow
Jaisin:
Try shifting without the clutch. It's actually better for the gearbox.
Stew
Old Feb 15, 2005 | 08:07 AM
Gambit's Avatar
Screw gas mileage
Jaisin...go to www.howstuffworks.com and look up manual transmission and clutch. That should enlighten you a bit.
Old Feb 15, 2005 | 08:14 AM
Luftwaffle's Avatar
It's my first manual. I'm still learning how to shift perfectly smooth, but I can get around.
Old Feb 15, 2005 | 11:59 AM
spork's Avatar
Foolio
Same here. I'm ok. First gear still gives me problems and very steep hills still scare me. Ugh, still waiting for mine to come back from the shop.
Old Feb 15, 2005 | 12:24 PM
Nubo's Avatar
Lubricious
^^ the handbrake maneuever is how you deal with starting off on steep hills.
Gambit's Avatar
Screw gas mileage
Yep...it's my first manual, first rotary, first sports car, first rear wheel drive, etc. I think I have learned to drive it perfectly fine, I'd probably be no good on a track or autox, but I can drive around as well as anyone else
Old Feb 15, 2005 | 12:49 PM
Luftwaffle's Avatar
Yeah, we don't have many steep hills around here, I can usually shift and clutch fast enough to get started without using the handbrake in my area. But, if I were ever in SF, I'd be screwed. I need to practice a few starts on a steep incline so that I have it available when I need it. My main problem right now is that I don't shift fast enough and let the revs drop too low while at the same time let off the clutch way too fast. I get really jerky shifts. Starts are AOK. :D
Old Feb 15, 2005 | 01:35 PM
spork's Avatar
Foolio
Hehe. yeah. I haven't had to use it yet. I've burned the clutch a bit on a few rare occassions though. It's not like I can't do it, it's I'm afraid of stalling or hitting the guy so I just panic slightly.
So glad I don't live in SF though. Hell, going up Lombard with an automatic was scary especially when people tend to ride your *** going up.
First gear for me is OK, I just don't like doing it and I always feel like it could be better. Somedays I'm jerky, some days I feel like a pro. Heh.
Old Feb 15, 2005 | 04:41 PM
Johnnyma45's Avatar
I learned on this car as well. Does anyone else think the gas/brake pedal is a little bit to close in relation to the clutch? I can't really find a perfect sitting position...either i'm stretching my left leg too far or my right leg is cramped.
Old Feb 15, 2005 | 06:31 PM
beachdog's Avatar
Jaisin, you would probably benefit from a clutch pedal extension. The 8's clutch is relatively long throw and a far reach relative to the gas and brake. Sitting too close to the wheel and airbags is dangerous. It also makes the reach to the shifter too close and makes the mirrors hard or even impossible to adjust accurately.
You can do a DIY or there are commercial products available.
https://www.rx8club.com/showthread.p...ighlight=pedal
You will be amazed at what a 1 or 2 inch extension will do for you.
Old Feb 15, 2005 | 08:11 PM
Jaisin's Avatar
Jason
Thats a lot of work considering I don't have any tools or any hardware skills. It lookes neat, but for the most part, I don't have any gripes with the current clutch position.
Old Feb 15, 2005 | 08:14 PM
Rhawb's Avatar
Has the whole shit.
Yeah, short guys are alright in this car. I can reach just fine without being crammed into the steering wheel. I can actually comfortably sit farther back in this car than any other manual car that I've driven.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
