Not just another Engine Light!
Old Feb 3, 2005 | 08:03 PM
EmperorJazzy's Avatar
Aussie Rx8
Angry Not just another Engine Light!
Greetings All,
I thought I would keep you all posted on my Engine Light saga. Just incase someone else comes across the same thing (and I hope no one does).
January 2005
- Sunday - Engine Light comes on upon starting RX8
- Monday - Engine Light is off when starting before heading to work.
Next Weekend
- Sunday - Engine Light comes on.
- Monday - Engine Light still on. Take RX8 down to Mazda. Hand over the RX8 for the day.
- Result: Reprogrammed Computer. No problem codes. Light is off.
2 Weeks Later
- Saturday - Engine Light comes on again. Goes off mid-afternoon.
- Sunday - Engine Light comes on again. Stays on.
- Monday - Engine Light is on. Take RX8 down to Mazda again.
- Result: Reprogrammed Computer. No problem codes. Light is off. Mazda to call Mazda Head Office.
Next Day
- Engine Light back on. Take RX8 down to Mazda again. Mazda have the car all afternoon.
- Result: Mazda called Mazda Head Office. In the end, Spark Plugs faulty. Wrong heat range. Spark Plugs changed to Range 6. Should 'solve' problem. Still no problem codes.
Next Day
- Engine Light back on. Take RX8 down to Mazda again. Mazda have car all day.
STILL IN THE WORKSHOP
Am I the only person with a problem like this?! I mentioned the Cat the other day, they reckon nothing is wrong. The only reason I persist is because I'm on holidays and can afford to take the car, back and forth. Otherwise, I'd be extremely crappy cos it was effecting my job.
I'll keep you all posted...... I wonder if a letter to Mazda Australia would do anything!?
JEZZAP
Old Feb 3, 2005 | 11:13 PM
takahashi's Avatar
Who did you bring it too....?
Have you try another one?
My money still goes to the catalyst ... Gomez want a guess?
If Mazda had called the head office - they will take care of it. The Mazda guy I met last time - they are extremely keen people and they will send people to the dealer to look at your car. I shall not worry.
Old Feb 4, 2005 | 12:15 AM
timbo's Avatar
rock-->o<--hard place
Hmm, I'd have a serious discussion with the Service Manager.
I think this has been raised before, and was a dicky cat converter -- maybe search and see.
May also be a buggered sensor somewhere, which trips at a given temperature.
You could always call Mazda Assist
Old Feb 4, 2005 | 05:24 PM
Gomez's Avatar
Shifty Bastard.
Odd. A faulty cat would throw a fault code. Strange that they clear the MIL/CEL but report no fault code.....
Old Feb 4, 2005 | 05:35 PM
Gomez's Avatar
Shifty Bastard.
BTW, I'd question the fitment of the hotter RE6A-L plugs. These are normally reserved for fitment in very cold climates or fitment to cars that are getting fouled plugs 'cos the owner is tooling around like an old granny. To the best of my recollection you are the first person in Australia who has reported having these plugs fitted.
Good luck Grandma,
Gomez .
Old Feb 7, 2005 | 01:39 AM
Aussie Rx8
Car comes back from Mazda that afternoon. Mazda Aust have stated there is a release about to come out about a possible engine light issue related the level of oil. This doesn't effect the low oil level lamp, just the Engine Light lamp. WEIRD?!
Took car home.
Next Day
- Engine Light back on. Saturday morning so I drive all weekend as Mazda said 'Bring it in on Monday if it happens again.'
Monday (Today)
- Engine Light still on. RX taken to Mazda and handed over. Explained to them AGAIN that they should check the Cat Converter and the CO2 Sensor. Noted for further examination.
End of the day, I'm now driving a Black Mazda 2. RX is still being looked at and MAY be back tomorrow. I've told them, I only want it back if it's been fixed.
*Update complete*
Regards,
Grandma! :P
Old Feb 7, 2005 | 05:12 AM
Gomez's Avatar
Shifty Bastard.
Mate, that is weird. Good luck with it. What is the build date of your car?
Old Feb 7, 2005 | 06:03 PM
rx88er's Avatar
Man...sounds very weird...at least they're looking into it, although you'd think they'd have it sorted out by now. Good luck and keep us all posted.
Cheers,
rx88er
Old Feb 8, 2005 | 04:14 AM
Aussie Rx8
The build is (from recollection) Jan 2004
- Mazda reported nothing of interest today. RX still in the workshop.
Old Feb 8, 2005 | 12:47 PM
Gomez's Avatar
Shifty Bastard.
Same as mine, Jan 2004. Never had a CEL myself. There was a problem with the sump on earlier deliveries, but it didn't cause a CEL if I recall correctly. That problem was all sorted by Jan 2004. Very strange.
Old Feb 9, 2005 | 12:52 AM
Aussie Rx8
It's quite possible it's over.
The car was returned today and supposedly, the issue will never come up again. (*cough cough*)
Ok
Monday - Wednesday
- Checked Cat Converter
- Changed Cat Converter
- Reflashed/Reprogrammed
- Engine Light came back on.
- Checked over every possible issue that causes the CEL to show
- Rang Mazda Australia
- Told to check 'Software' of PCM in detail.
- Mazda checked software.
- FOUND POSSIBLE ISSUE
- Tech reflashing wasn't saying yes to 'Does this vehicle have DCS?'
- DCS was missing in the system, and thus the ABS wasn't working. Sending mixed signals to the DCS/PCM. Engine Light going on from fault. No problem code.
- Reprogrammed PCM manually bit by bit. All systems checked Ok. No Engine Light.
The big test is tomorrow morning. If the engine light comes back on, you'll hear me scream!!
Looks positive though gents! And to think there was a problem with the car when all along it was the all knowledgable Mazda Tech.
Thanks for all your suggestions guys! At least I got a new CAT CONVERTER. :P
Old Feb 9, 2005 | 01:03 AM
timbo's Avatar
Sounds like a dicky PCM
Old Feb 9, 2005 | 02:19 AM
takahashi's Avatar
Mazda might have loaded the MazdaSpeed RX-8 version in the PCM by mistake.
Now you just have the G flash.
J/K :D
Good outcome and a free "unscratched" cat! Perfect
Old Feb 10, 2005 | 04:11 PM
rx-8club.co.uk's Avatar
Really makes you wonder why they didn't replace the ECU with a temporary one early on.
Would have certainly helped to solve the problem earlier!
Thanks for the info.
Old Feb 11, 2005 | 01:57 PM
Hymee's Avatar
Race Steward
- DSC was missing in the system, and thus the ABS wasn't working. Sending mixed signals to the DSS/PCM. Engine Light going on from fault. No problem code.
Un-fuggin-believable
PCM = OK.
CAR = OK.
TECH = Tosser.
(all comments above pending EJ's next post!)
Cheers,
Hymee.
Old Feb 14, 2005 | 03:46 AM
Aussie Rx8
1 Week on...... ALL CLEAR!!!
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
