Keyless entry fob problem
Old Jan 25, 2005 | 05:20 PM
SlAoTkAiN's Avatar
During the last few days when I turn off my factory alarm I have to wait unil I"m right up on the car before it picks up, and the blinkers go off. I've already changed the battery and it's still doing it, anyone else having this problem and know of a way to fix it?
Old Jan 25, 2005 | 06:49 PM
rx8cited's Avatar
Senior Member
Have you tried your second fob? Could the new battery be bad?
Old Jan 25, 2005 | 07:19 PM
SlAoTkAiN's Avatar
the other one's doing the same thing, and I tried it, and then replaced both batteries
Old Jan 25, 2005 | 07:52 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
i've noticed that they don't have a very far range... i have to be within 100 feet from the car for it to work. My jeep would work up to a 1/4 mile no prob, but that was a after market alarm. so i dunno
Old Jan 25, 2005 | 09:05 PM
truemagellen's Avatar
Attracts tree branches
I noticed the range on the 04 FOB blows...BUT in the manual it says max is under 30 feet or something? maybe worse I can't remember
The 05 FOB is WAY WAY better...over 50 ft atleast and only gets better when you extend the key it is like an antenna which is odd since the 'key' and the 'fob' of the 05 only have plastic connecting them
Old Jan 25, 2005 | 09:10 PM
SlAoTkAiN's Avatar
well unless I'm within ten feet of my car the fob doesn't work does it have to be reset to the car? I had the HU defroster buttons replaced, coudl the dealer have done something that cleared out the fobs?
Old Jan 26, 2005 | 06:51 AM
rx8cited's Avatar
Senior Member
SlAoTkAiN, sounds like the car needs to go to the dealer.
Try this ........ next time you're far from your car, hold the fob up next to your neck with the fob pointing towards the car and hit lock or unlock buttons........ you body acts as an antenna and you get extended fob range :D.
Old Jan 26, 2005 | 07:18 AM
Gomez's Avatar
Shifty Bastard.
Funny, I get 300 yards easy.....Jan 04 build.
Old Jan 26, 2005 | 07:36 AM
DreRX8's Avatar
Mine is funny--sometimes I have to be right up on the car--other times I can unlock it from the other side of town. Not worried about it-cause I plan on getting the 05 setup.
Old Jan 27, 2005 | 10:32 PM
Mikelikes2drive's Avatar
i get at least 50-75 yards on my 04. i lovemy range
OnebaddRx8
Aug 25, 2019 11:34 PM
Hdez Mex
Sep 24, 2015 02:47 AM
ErwinN
Sep 23, 2015 09:29 PM
Vedivan1
Sep 18, 2015 12:39 PM
