Temporarily Disabling Driver's Door Switch
Old Jan 23, 2005 | 08:11 PM
TheDosDog's Avatar
Recovered Modaholic
I found this rocker and installed it to interrupt the driver's door switch. When I'm detailing the car and listening to tunes it makes the car think the driver door is closed and turns off the chime. When I'm done I can flip the rocker to reenable the door switch so it functions normally.
Old Jan 23, 2005 | 08:19 PM
TheDosDog's Avatar
Recovered Modaholic
No Gomez, I read your DIY. I wanted to maintain function and turn it off just when not needed.
Old Jan 23, 2005 | 08:20 PM
Gomez's Avatar
Shifty Bastard.
Yeah sorry, I figured you had it all sorted so I deleted my post......
Old Jan 23, 2005 | 08:21 PM
Gomez's Avatar
Shifty Bastard.
The switch looks neat....
Old Jan 24, 2005 | 06:02 AM
rx8cited's Avatar
Senior Member
Nice! What did you have to remove to do this mod?
Old Jan 24, 2005 | 07:35 AM
TheDosDog's Avatar
Recovered Modaholic
Not much. I pulled loose the bottom of the rear door panel (did not need to remove) and drilled a small hole on the side for the rocker. There is a single white/red wire going to the switch in the rear door. I cut that wire, then wired the rocker switch in line. I bought the switch at Radio Shack (275-693).
Old Jan 25, 2005 | 03:00 AM
BVD's Avatar
BVD
Nice neat job with the switch.
However, for owners with less DIY skills who don't need this ability all that often, you can always use a low-tech el-cheapo solution like mine.....
I'm sure that that most owners could obtain a similar part from a branch near them...
Old Jan 25, 2005 | 04:19 AM
Paul_in_DC's Avatar
Rotary Public
Q: Is pine acceptable or does it need to be a hardwood, like oak?
Old Jan 25, 2005 | 05:20 AM
BVD's Avatar
BVD
Personally, I prefer a nice piece of Australian eucalypt, but I'm sure that just about any wood would do the job.
Of course, for anybody living in a stick-challenged area, there are many other options. Just about anything can be used to wedge the button and convince the electronics that the car door is closed.
Vegetarians may be attracted to the carrot option shown below, cooks may prefer the kitchen spoon method, and parents may gravitate towards the toy giraffe solution....
They all work.
Attached Thumbnails Temporarily Disabling Driver's Door Switch-carrot01.jpg   Temporarily Disabling Driver's Door Switch-spoon01.jpg   Temporarily Disabling Driver's Door Switch-giraffe01.jpg
Old Jan 25, 2005 | 05:32 AM
Go48's Avatar
They all work.
Mais où est l'élégance? :D
Old Jan 25, 2005 | 09:14 AM
rx8cited's Avatar
Senior Member
LOL :D. Don't forget to take them out when you close the door .
vapor2
May 4, 2020 03:53 AM
vapor2
Sep 19, 2015 05:33 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
czr
Sep 13, 2015 11:37 AM
