New final drive gear available
Old Jan 20, 2005 | 03:59 PM
PUR NRG's Avatar
OEM ratio is 4.44. For only $3800, Mazda Motorsports sells a 5.12 ratio final drive gear...
I don' t expect any but the most hardcore to buy something like this, but I wanted to let people know it's available.
________
MONTANA MARIJUANA DISPENSARIES
Old Jan 20, 2005 | 04:12 PM
Relentless's Avatar
$3800?
Old Jan 20, 2005 | 04:16 PM
Fanman's Avatar
damn, $3800 is rough. I wouldn't mind a higher final drive ration in the 1st 4 gears, but I am pretty much already at 4000 rpm+ crusing on the freeway in 6th, so the last thing I need is to increase the revs at that point.
Old Jan 20, 2005 | 04:57 PM
PUR NRG's Avatar
Well either you re-gear 1st through 4th or you put in a new final drive gear. As expensive as this one is, which do you think is the cheaper option?
________
Redhead Cam
Old Jan 20, 2005 | 05:22 PM
Ajax's Avatar
yeesh.. that'd reak hell on gas mileage.. if i were to do that, i'd have to pull 6th gear all together and get a different ratio gear so I could cruise at like 3000rpm at 80..
Old Jan 20, 2005 | 05:35 PM
takahashi's Avatar
$3800 US... hang on it is about $5000 AUD.
But Fujita engineering has a 4.777 final drive for less than $1000AUD! Yen 68,250
$3800 is a bit steep
Last one on the list
http://www.fujita-eng.com/rx8/index.html
Old Jan 20, 2005 | 06:46 PM
Relentless's Avatar
That's $725.95 USD here:
http://www.jt-imports.com/FEED_RX8_Parts_List.htm
Old Jan 21, 2005 | 03:13 AM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
That's awesome that it's out, but seems to be a bit too expensive. I think Taka's suggestion of the 4.7 will do fine, won't murder gas mileage but will give the car a nice extra pep.
Old Jan 21, 2005 | 03:41 AM
shaolin's Avatar
Yes, I agree. I bet it would be an awesome upgrade for autocrossers to get a little more oomph on corner exit.
Old Jan 21, 2005 | 08:33 AM
trophymaker's Avatar
Even with the stock rearend I long for a 7th ratio on the highway...
Old Jan 21, 2005 | 09:37 AM
AQA101's Avatar
Stainless
My thoughts exactly, I'm often driving long distances at autobahn speed and would appreciate another gear to keep the revs down. I got used to shift down two gears at once for acceleration in most situations, so a seventh gear would fit perfectly.
Old Jan 21, 2005 | 10:04 AM
PUR NRG's Avatar
The 5.12 gear (and transplanting the j-spec 5 gear tranny) are both intended for track use. Autocross benefits as well but that wasn't the intended market.
________
Lovely Wendie99
Old Jan 21, 2005 | 11:10 AM
Zaku-8's Avatar
I think replacing 5th and 6th would be easier than installing a 7th gear
Old Apr 28, 2005 | 06:45 AM
takahashi's Avatar
Sorry to dig this thread up.
But any recalibration of the speedometer required when you install the final drive gear, say for 4.7 or 5.12? Thanks
Old Apr 28, 2005 | 06:47 PM
ILIV48's Avatar
If the sensors for the odometer are to do with the wheels or driveshaft etc then I would say no as these are after the Diff. I would be tempted to do the 4.777 as I think the car would be a lot more fun but it's a daily driver so I don't think I could afford the fuel which is already costing me over $100.00 a week
05TR1CH
Apr 18, 2023 04:56 AM
Nisaja
Apr 14, 2019 08:04 AM
k4thomas
Aug 5, 2015 03:03 AM
