How about a FAQ on abbreviations
Old Jan 18, 2005 | 09:43 PM
No More Oldsmobiles's Avatar
Custom User Title:
How about a sticky with common abbreviations? Just some I've seen recently:
OBDII or OBD-II. On-Board Diagnostic system.
CEL: Check engine light.
TPMS: Tire pressure monitoring system
Old Jan 18, 2005 | 09:46 PM
Omicron's Avatar
Good idea! Start building one for us, and we'll make sure it gets integrated into the FAQ that Zoom44 is working on.
Old Jan 19, 2005 | 08:12 AM
Gambit's Avatar
Screw gas mileage
WOT: Wide Open Throttle
Old Jan 19, 2005 | 11:34 AM
czr's Avatar
czr
RX8 RX8!
dsc:dynamic stability control
tsb:technical service bulletin
lsd:limited slip differential
tcs:traction control system
dstc:dynamic stability and traction control
ok ttyl
Old Jan 19, 2005 | 11:47 AM
bowman's Avatar
SA/FB=1st Gen RX-7
FC=2nd Gen RX-7
FD=3rd Gen RX-7
FE=RX-8
Old Jan 19, 2005 | 12:09 PM
czr's Avatar
czr
RX8 RX8!
FI: forced induction
NA: naturally aspirated
Old Jan 19, 2005 | 02:38 PM
Custom User Title:
Omicron, this is a good start. Everyone can post abbreviations as they think of them. When Zoom44 is ready to update the FAQ, give me a heads-up and I'll alphabetize the list.
Old Jan 19, 2005 | 07:12 PM
Omicron's Avatar
Originally Posted by bowman
FE=RX-8
Nope... RX-8 not = FE. RX-8 = SE3P
Old Jan 19, 2005 | 07:33 PM
bowman's Avatar
That is far from universally accepted. I was going to include both but I could not remember the 2nd and all I had to go on was my VIN .
Old Jan 26, 2005 | 12:21 AM
juikster's Avatar
Im 8 drifting on a budget
can you tell me how do you add a pic in the text area without it being a thumbnail.
Old Jan 26, 2005 | 01:33 AM
RotaMotion's Avatar
Felix the Wankel!
WTF is a FAQ?
:D :D :D :D
Oh, and my contribution RTFM (Read The Fabulous Manual)
Old Feb 26, 2005 | 05:07 PM
Mugatu's Avatar
Even My Dog Searches
TTIUWP = this thread is useless without pics :D
Old Feb 26, 2005 | 07:52 PM
truemagellen's Avatar
Attracts tree branches
Pos= :D
Old Feb 26, 2005 | 07:53 PM
PCM=powertrain control module
Old Feb 26, 2005 | 08:01 PM
DTC=Diagnostic Trouble Codes
A/C=Air Conditioning
ABS=Anti-Lock Break System
SAE=Society of Automotive Engineers
oh BTW wide open throttle is "WOP" for SAE standards
Old Feb 26, 2005 | 08:12 PM
ABBREVIATIONS
ABS Antilock Brake System
ACC Accessories
ALR Automatic Locking Retractor
API American Petroleum Institute
APV Auxiliary Port Valve
AT Automatic Transmission
ATF Automatic Transmission Fluid
CAN Controller Area Network
CCM Comprehensive Component Monitor
CM Control Module
CPU Central Processing Unit
DC Drive Cycle
DSC Dynamic Stability Control
DTC Diagnostic Trouble Code
EBD Electronic Brakeforce Distribution
ELR Emergency Locking Retractor
EPS Electric Power Steering
FFD Freeze Frame Data
F/P Fuel Pump
FP1 Front Primary 1
FP2 Front Primary 2
FS Front Secondary
GPS Global Positioning System
HI High
HU Hydraulic Unit
IG Ignition
INT Intermittent
KAM Keep Alive Memory
LCD Liquid Crystal Display
LED Light Emitting Diode
L/F Leading Front
LF Left Front
LH Left Hand
LO Low
L/R Leading Rear
LR Left Rear
LSD Limited Slip Differential
M Motor
MAX Maximum
MIN Minimum
MSP Multi Side Port
MT Manual Transmission
P/W CM Power Window Control Module
RF Right Front
RH Right Hand
RP1 Rear Primary 1
RP2 Rear Primary 2
RR Right Rear
RS Rear Secondary
SAS Sophisticated Air Bag Sensor
SAE Society of Automotive Engineers
SST Special Service Tool
SSV Secondary Shutter Valve
SW Switch
T/F Trailing Front
TCS Traction Control System
TFT Transmission Fluid Temperature
TNS Tail Number Side Lights
TPMS Tire Pressure Monitoring System
T/R Trailing Rear
VDI Variable Dynamic Effect Intake
VFAD Variable Fresh Air Duct
WDS Worldwide Diagnostic System
Old Feb 26, 2005 | 10:37 PM
robertdot's Avatar
TDC = Top Dead Center
ATDC = After Top Dead Center
BTDC = Before Top Dead Center
BDC = Bottom Dead Center
ABDC = After Bottom Dead Center
BBDC = Before Bottom Dead Center
rotarywanker
Dec 8, 2022 05:56 PM
Supernaut6
Aug 11, 2015 07:28 PM
zoom44
The RX-8 FAQ
Jun 10, 2005 04:13 PM
