Body lean
Old Jan 15, 2005 | 01:06 AM
Matt RX8's Avatar
Body lean
I've seen write-ups on the RX-8 that discuss excessive body lean.
To be honest, I didn't feel it, and I put it through the paces pretty hard on my test drive.
I'd like to track and autocross this car stock. Not looking for phenomenal performance, just enough to raise the eyebrows of my Audi and BMW friends.
What are your thoughts of the stock RX-8 as a track/autocross car?
Old Jan 15, 2005 | 01:25 AM
ZoomZoomH's Avatar
Mulligan User
assuming all your bmw/audi friends also have stock suspension, your car should be able to whip them good in autox, assuming the nut behind the wheel isn't a loose one :D
Old Jan 15, 2005 | 01:37 AM
NomisR's Avatar
Body roll on this car is probably more than it's competitors ie 350Z, G35 and more expensive one, probably more so than less expensive budget pocket rocket too. It's not as noticible in daily driving but once you push it, there's a lot of roll which takes some getting used to but the car holds right there.
Old Jan 15, 2005 | 02:11 AM
hotpot's Avatar
On a track, if the curve is properly banked, it would not be very noticeable.
On the road you can definitely notice the body roll if the road around a curve is not banked.
Old Jan 15, 2005 | 08:45 AM
Matt RX8's Avatar
Do you think the body roll would prohibit the RX8 from being a good track/autocross car?
Old Jan 15, 2005 | 09:06 AM
ZoomZoomH's Avatar
Mulligan User
if the driver can overcome their instinct to slow down as the body starts leaning, it will do just find in autox/track. Of course, an 8 with a stiffer suspension will naturally have better handling (which includes less body roll), but I think in stock form it is quite good.
Old Jan 15, 2005 | 09:36 PM
AlexCisneros's Avatar
My former car was an Audi S4, I've tracked it and the RX8. While the speeds in the S4 were greater on the straights the lap times were faster in the 8. Now I can't speak for the new model M3, but the S4 was very comparable to the 330 (probably why they were both in D-Stock).
To answer your question. You may find that the RX8 can embarrass some BMW's and Audis. It can also embarrass Turbo Porsches and Ferraris, driver dependant of course
The body roll is not as severe as you may think (especially compared to the S4), but to be competitive sway bars and stiffer shocks is the way to go.
Old Jan 16, 2005 | 07:45 AM
MI_FamilyMan's Avatar
Sold on Rotaries!
Alex, are you talking about the V8 S4 or the previous generation S4?
That would be a beautiful thing watching an 8 embarass a Porsche or Ferrari... I know I wouldn't have the skill to do it, but it would be neat to watch someone do it.
Old Jan 17, 2005 | 05:25 PM
I had the V6TT
...yeah, it was fun They put me in Green Run Group at a NASA event
Old Jan 18, 2005 | 12:49 PM
Ophitoxaemia's Avatar
dizzy snake pilot
"body lean" is not inherent in a make and model of car. it can be calculated based on the suspension geometry and components. you can easily modify your rx8 to have almost any amount of lean you want, primarily through spring and sway bar selection.
the rx8 has a wonderful handling dynamic, in part because of the low, small and light engine. but like most street cars, the suspension is tuned very soft and exhibits a lot of 'body lean' (also called 'body roll').
james
Old Jan 18, 2005 | 01:35 PM
124Spider's Avatar
If I fit in our RX-8 with a helmet, I'd be happy to take it on the track or autocross it. Yeah, it leans more than my S2000, but it's not "excessive," IMO. If you're just out to have fun, the RX-8 with its stock setup should be very serviceable, except I would replace the stock pads with a racing/street hybrid pad if you were to take it on a track.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Digitz0070
Sep 27, 2015 07:49 AM
