Source and best price on Rays Volks?
Old Jan 13, 2005 | 09:35 PM
Omicron's Avatar
Anyone got a good source for Rays Volks? These are the same as the MS wheels (and like only 17.6 Lbs!) but are apt to be cheaper... but I can't find a vendor. Can anyone help?
Old Jan 13, 2005 | 09:38 PM
flip's Avatar
LOVE / HATE Relationship
Try here... Good luck! Love them wheels.. :D
http://www.finalstageauto.com/tuner-wheels1.htm
Old Jan 13, 2005 | 10:25 PM
whosyourbaba's Avatar
http://www.importhookup.com/forums/s...hp?threadid=21
http://www.importhookup.com/forums/s...hp?threadid=22
Old Jan 13, 2005 | 11:42 PM
Cam's Avatar
Cam
this space for rent
All of the following sell Volk wheels. Good luck on the search.
http://www.gruppe-s.com/
http://www.fizzautosports.com/
http://upgrademotoring.com/index2.htm
http://www.wheeloptions.com/main.html (supplier for rims on Importhookup.com)
http://www.permaisuri.com/home3.html
http://www.wheelsboutique.com/DEFAULT.asp
http://e-wheelz.com/enter.html
http://store.finalstageauto.net/index.html
http://www.godspeedinc.com/
http://www.optionimports.com/
http://www.nonstopmotorsports.com/index.html
http://www.i-m-racing.com/wheels.html
http://www.lightspeedmotorsport.com/news.shtml
http://www.carismaautotec.com/default.asp
http://revhighonline.com/page.php?na...rt&action=main
http://www.forperformance.com/products.html
http://www.hopupracing.com/index.html
Old Jan 14, 2005 | 02:57 PM
Omicron's Avatar
Great, that helps folks. But....
I thought "Rays Volks" are different from VOLKS wheels... Volks I can find, just not the Rays version. Looking at all the Volks, the Mazdaspeed wheel looks different... not exactly like any of the Volks.
So, any suggestions?
Old Jan 14, 2005 | 04:34 PM
Relentless's Avatar
Rays Engineering makes the Volk Racing branded wheels. I think the MS wheel must be MS-only, but made by Rays. Rays also makes the wheel for the Track-model 350Z, and I think the wheel is available only for the Z. So the only way to get that particular wheel model would be to get the Mazdaspeed version.
Jeff
Old Jan 14, 2005 | 04:43 PM
Audioslave8's Avatar
http://www.finishlineperformance.com...&preadd=action
**EDIT these are the ones from the picture, i dont think this is what u were looking for**
Old Jan 16, 2005 | 11:38 AM
Omicron's Avatar
Nope, I want the non-Masdaspeed-branded versions of these wheels. But thanks.
Anyone?
Old Jan 16, 2005 | 12:01 PM
Relentless's Avatar
I don't think they exist.
Old Jan 16, 2005 | 12:17 PM
xSxxKxxYx's Avatar
umm... never bought any rims be4... wut are those other measuring numbers other then just 18'' wut do i need for the RX-8 if i wanted 18x8.5 don't get it... plz help!!
Old Jan 16, 2005 | 12:38 PM
Omicron's Avatar
4 main measurements to make it fit:
  • Bolt pattern and size: In the case of the RX-8, it's 5 x 114.3
  • Offset: In the case of the RX-8, it's 50mm. Other offsets will fit up to about 40mm without major problems.
  • Wheel diameter: 18 inches is standard on the sport model and up
  • Wheel width: 8 inches on the 18 inch wheels
So the factory rim is 5x114.3, 50mm, 18x8. Some people have put larger sizes on, eg, 19 and 20 inch wheels, but this is pretty much just for show. If you want performance, smaller diameter 17" wheels will actually help acceleration a little bit.
One other thing to consider: Wheel weight. The factory 18" wheels weigh about 23 Lbs each. Larger wheels usually weigh more. If you're after performance you definitely don't want heavier wheels as they add "unsprung weight" which is the worst kind.
What I'm trying to do is stay with 18" wheels and find something that both looks good and weighs less.
Hope this helps.
Old Jan 16, 2005 | 01:08 PM
blksf8's Avatar
do you really need to get Rays or Volks? SSR has a few different types of wheels (the most known one is the competitions) where weight for 18x8 or 18x8.5 is 16.9lbs or 18 or so lbs max. They are good wheels, but they'll run you about $450-$500 a piece.
Old Jan 16, 2005 | 01:49 PM
Relentless's Avatar
You might also consider the Volk TE37 and CE28. Both are about 16-17lbs depending on wheel width.
Old Jan 16, 2005 | 07:33 PM
Omicron's Avatar
My goal is some weight savings without spending $2000 for a set of wheels, but I appreciate the suggestion. The first ones I considered was the SSR Comps that Tirerack sells, but don't really want to spend that much. Thanks for the input though!
Old Jan 16, 2005 | 07:34 PM
Omicron's Avatar
Believe me, I've noticed them too. :D
Old Jan 16, 2005 | 07:40 PM
blksf8's Avatar
Volks are expensive though. You'll be paying at least $1600-1700 for a set of 18s.
Old Jan 16, 2005 | 08:18 PM
RotorManiac's Avatar
Absolute Rotary Madness
Originally Posted by Omicron
What I'm trying to do is stay with 18" wheels and find something that both looks good and weighs less...
We are on the same path here Omi.
My thoughts: I'm between the ce28 and the GT-N. monoblock vs 2piece, lighter vs better looking... I'm also staying with 18 (18x8fr,18x9rr) since 19 are too expensive & heavy.
I'd buy the ce28 straight away (its only 16-17lbs!) if the gt-n is much heavier, but I can't find the weight for this one In mine opinion, the ce28 looks better than the te37. However, the gunmetal gt-n will be just great on my black 8. You see, I simply can't decide:o
What I don't know yet, is the offset (not sure what values are good to have) and what tire dimensions to put on...
Help anyone?
Attached Thumbnails Source and best price on Rays Volks?-volks-gt-n.jpg   Source and best price on Rays Volks?-volk-ce28.jpg
Old Jan 16, 2005 | 08:24 PM
blksf8's Avatar
I like the CE28s as well in titanium silver. Anyone have these on their 8 yet?
Old Jan 16, 2005 | 08:45 PM
Relentless's Avatar
If you're looking at 18s, I would get the CE28s either in 18x8.5 or 18x9, both come in +40 offset. You can fit 245/40 tires on either wheel. But if you go with 18x9s, you can always get wider tires.
Old Jan 16, 2005 | 08:48 PM
Relentless's Avatar
If you're looking to not spend $2k, I think Volks are out of the picture. You might look at Enkei wheels, most of which will run about 19-20 lbs each in 18x8.5 or 18x9, but will be much much cheaper. But I think they look cheap too.
Old Jan 16, 2005 | 10:14 PM
joyridevr6's Avatar
0.19 posts per day
I bought my volks from Rishie at autornd he has a spot in the vendor section of this site. I could find no better price than what he offered.
Old Jan 18, 2005 | 07:35 PM
Omicron's Avatar
Help anyone?
You see this thread?? :D
Old Jan 18, 2005 | 08:41 PM
haha nice one paul, even if I seriously wanted his rims... this guy doesn't ship in the US, do you think I'll convince him to ship to Europe?! :o
Old Jan 18, 2005 | 09:41 PM
Omicron's Avatar
LOL, oops. Forgot you were in Greece. :D
Maybe you could find someone in SoCal to buy 'em for you and ship them to you?
Old Jan 18, 2005 | 10:04 PM
brillo's Avatar
Go Texas Longhorns!
Omi,
I've done alot of research, and unfortuantely, to get any truly light weight wheels, you looking at spending at $2K for the wheels. You could save some money on the lighter weight enekei types, but I hear they are alot more fragile. the closest wheel to the MS one is the SSR GT2, and they are about $450 a wheel? and really light. Match them with a good set of Toyo's and your talking about a 8lb saving per wheel. I think to really feel the difference, you'd have to go that light....so all in your talking 3K with tires, which as someone will surely point out, is as much as a turbo kit.
I'm going to start buy getting lighter weight tires when mine burn out, see how that feels, and then decide. I may decide still to go the light weight 8 option, and rather than turbo the car, just strip as much weight off as I can to get the car down to the 2600lb range.
Good wheels also have a good resale value on Ebay for what I can tell, if you decide to get rid of them in the future. If I could only find 10K on the street, these decisions would be so much easier......
