Water getting into engine
Old Jan 9, 2005 | 05:52 PM
max_rx8's Avatar
Exclamation Water getting into engine
Has anyone had any problems with water getting into their engine?
Old Jan 9, 2005 | 05:55 PM
Dlrosie's Avatar
GotZoom
Water from........3 1/2 feet of rainfall? Driving through a lake?
Old Jan 9, 2005 | 06:03 PM
max_rx8's Avatar
lol, please be serious
Old Jan 9, 2005 | 06:10 PM
Dlrosie's Avatar
GotZoom
Max...do you know where the water is coming from?
Old Jan 9, 2005 | 06:17 PM
max_rx8's Avatar
I have no idea
Old Jan 9, 2005 | 07:06 PM
Maolin34's Avatar
Ok.... Why do you think that there is water in your engine? What symptoms are you having that leads you to believe this?
Old Jan 9, 2005 | 07:14 PM
max_rx8's Avatar
On inspecting the engine oil i found water mixed with the oil,i noticed a white moisture on the dip stick
Old Jan 9, 2005 | 07:18 PM
Maolin34's Avatar
If you are talking about the creamy substance on the dipstick, there is a problem with moisture making its way into the dipstick tube. Mazda has a new TSB to fix this with a new dipstick tube, and possibly a new dipstick. I assume that is where you are finding the water. This is happening only in areas where the weather is cold. It will most likely not be a problem in the summer.
There are lots of posts about this, some including pictures of the new dip tube.
Old Jan 9, 2005 | 07:21 PM
max_rx8's Avatar
Thanks for the info,
so will mazda warranty fix this problrm?
Old Jan 9, 2005 | 07:22 PM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/search.php?searchid=341794
Old Jan 9, 2005 | 07:25 PM
Maolin34's Avatar
Originally Posted by Maolin34
Mazda has a new TSB to fix this with a new dipstick tube, and possibly a new dipstick..
TSB's are technical service bulletins, you can find a list of current TSB's here...
http://www.finishlineperformance.com...ocs/index.html
Old Jan 9, 2005 | 07:31 PM
max_rx8's Avatar
Thanks again, i will be calling the dealer tomorrow to get the prob fixed
Old Jan 10, 2005 | 05:55 AM
Go48's Avatar
As far as I can determine, there is no TSB on this "problem". There IS an informational TSB on the new dip stick. Nothing about the creamy stuff. Apparently there is a "fix" available for those owners who are concerned about the stuff, but the "problem" is essentially cosmetic and not something worth worrying about. In my opinion, the so-called fix could turn out to be worse than the "problem".
Old Jan 10, 2005 | 06:28 AM
expo1's Avatar
He's as bad as Can
Having seen this question come up over and over I have a question for those owners that live in colder climates and do their own oil changes. When you drain the oil do you see “milky stuff” in the pan? If you only see the milky globs on the dipstick but NOT in the oil then your really not getting water in the oil. It’s just as has been reported here before a temperature / condensation issue with the dipstick. So I am curies to find out is the “ milky stuff” in the oil or just on the dipstick?
I have owned my 8 since 2/2004 and have had this “issue” both winters. Goes away in the spring and my 8 runs fine. I also get oil changes every 3,500 miles.
Old Jan 10, 2005 | 09:42 AM
Go48's Avatar
If the oil in the pan is hot when changed, as I would expect, I don't think you would see the milky substance--i.e., the water condensate-oil emulsion formed in the cold temp environment of the dipstick tube. However, I WOULD think that significant amounts of water in the oil would show up as water globules suspended in the oil since oil and water don't really combine/mix very well under normal conditions. Of course, if you see that, you got REAL problems, not just a little milky goo in the dipstick tube and you would likely see other indications of the problem as well.
Old Jan 10, 2005 | 01:23 PM
Haze's Avatar
Actually, water in the pan of a reciprocating engine from say, coolant, mixed at heat comes out as vaseline, or lumpy brown gooey chunks. Kind of gross actually. If memory serves, I did not get this kind of thing out of the pan of the RX 8 when I had lots of milky stuff on the dipstick, but I only do half of my oil changes since I get the other half free from Mazda in exchange for some horse power.
Old Jan 12, 2005 | 05:14 PM
Silvermister's Avatar
Get reddy for TURBO 8
I live in New Jersey and I also have seen this "white substance" on the top of my dip stick tube in cold weather. Nothing has happened as far engine problems, but hopefully we can find out how to remedy it.
Old Jan 12, 2005 | 10:55 PM
Maolin34's Avatar
As I said previously, the idea that Mazda had was to replace the dipstick tube with a one that contains a sleeve, and a thicker dipstick. There was a post where one RX8 owner took pictures of the new dip tube...it showed a blue sleeve inside the dip tube. Moisture in the oil finds its way into the diptube which is not has hot as the oil itself. The moisture collects there and tends to mix with some amount of oil...leaving the residue, and in my case water droplets on the dipstick. I imagine that the rest of the moisture in the oil that does not make its way to the dip tube, is evaporated in the heated oil....one question I do have, can anyone effectively explain why we see our exhaust as vapor? Where is the moisture coming from? The obvious answer to me would be moisture in the air, or condensation on cold metal components in the engine....however, I would expect this to stop once the engine reached operating temp...???
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
RXeckless
Aug 16, 2015 12:51 PM
Yayforaddison
38
Jul 31, 2015 11:28 AM
