Low Oil Pressure?
Old Dec 28, 2004 | 07:44 AM
Broke_Apex_Seal's Avatar
Low Oil Pressure?
Just wondering what your oil pressure gauge reads? Mine sets 2 ticks past the middle. I saw a pic in a mazda brochure and it sets like 4 ticks past the middle. Can anyone confirm where theres sets for me.
Thanx in advance.
Old Dec 28, 2004 | 08:08 AM
Butch Brown's Avatar
Mine is 1/8th inch past middle at idle.
Old Dec 28, 2004 | 08:15 AM
MazdaManiac's Avatar
Doesn't matter - it doesn't function, anyway. It is an "on/off" gauge. If you oil pressure drops below 15 PSI or so at idle, it will show zero. Anything above that (running pressure is 50 PSI), it will show somewhere around half.
Old Dec 28, 2004 | 09:26 AM
I was pretty sure it used to be a little higher than what it is now. When I start it it takes a good bit of time to raise up.
Old Dec 28, 2004 | 09:35 AM
Slims8's Avatar
Piston Traitor
Nope, it's a "dummy guage". On or off. When it gets real low it will start swinging to 0, then back up. When it gets any lower it will stay down... then... boom! 'nuff said.
Old Dec 28, 2004 | 09:38 AM
Have you had a PCM recalibration (flash) lately?
I know that mine sits lower now that I had MSP04 completed.
I was on "L" before.
Old Dec 28, 2004 | 10:45 AM
Yup! that is what I thought it was. Since the flash it has sat a little lower but I tell you this thing sounds a dump truck in the morning!
Old Apr 1, 2005 | 11:23 AM
guitarjunkie28's Avatar
port hacker
emme recycle this thread... 50 psi??? isn't that a bit low to be turning 9k rpm's?
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
