Spring Install: Piston Rod Top Locknut Question
Old Dec 24, 2004 | 12:29 PM
Low Fly'n 8's Avatar
Question Spring Install: Piston Rod Top Locknut Question
I have a few questions:
Does the piston rod top locknut have to be removed / installed using an air powered impact wrench? Why does Tein say to replace with new nuts and not to reuse this part? Are there any other special tools required for a spring swap?
HD
Old Dec 24, 2004 | 01:14 PM
rx8power's Avatar
Boricua Hasta La Muerte
By a mechanic's point of view, "Locknuts" should never be reuse by it's not gonna hurt if you use the old ones. Now, when it comes to removing it, make sure you use a spring compresor, if you use a powered tool is a lot better, but if you dont have one, you have to insert and allen wrench on the tip of the piston rod to hold it in place.
Good luck, and be SAFE!
RX8Power
Old Dec 24, 2004 | 01:55 PM
09Factor's Avatar
Original Turbo 'd Auto !!
I ran into the same thing you just did. I reused the old nuts however. It takes a little work w/ a wrench and an allel key, but it comes off.
let us know how long it took to do all 4 springs.
I was able to swap all for in 5 1/2 hours. I'm trying to toot my horn, I'm just curious..
have fun.
UHATEIT
Mar 31, 2019 05:31 PM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
WingleBeast
22
May 23, 2016 09:22 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
GracefulShanks
Aug 18, 2015 11:40 AM
