No more squeek!
Old Dec 23, 2004 | 07:49 PM
nhguy's Avatar
Thumbs up No more squeek!
As mentioned in earlier threads, my front driver's seat sounded like an old broken couch. The dealership tried to fix the problem two times without success. I demanded the seat be replaced and they did! It was an $1100 replacement (obviously covered by warrenty) and now there is no more squeek!!
Old Dec 31, 2004 | 11:33 AM
mitchmiller's Avatar
where is that dealership? Sounds like they are worth dealing with
Old Jan 1, 2005 | 01:11 PM
nhguy's Avatar
Concord, New Hampshire
Old Jan 1, 2005 | 06:00 PM
khoney's Avatar
FX8TED on my RX-8
Was it a squeek or a creak? Mine creaks a lot when I get in and when I turn corners. Seems to get better as the car warms up.
Old Jan 2, 2005 | 08:54 PM
nhguy's Avatar
It was actually a creak. It sounded like a broken bed or couch when you sat down on it or went around a corner.
Old Jan 3, 2005 | 06:10 AM
rx8cited's Avatar
Senior Member
What's the difference between a creak and a squeak ?
Old Jan 10, 2005 | 12:49 PM
Data's Avatar
I'm not sure if there is a difference. Either way, if the driver's seat is making a noise when cornering, it can be repaired by the dealer. It is also covered under the warranty. There's a known issue with the seat mount. Once it is replaced, your good to go.
Leesha
Canada Forum
48
Mar 1, 2008 10:22 AM
aaymax
Jan 30, 2005 07:51 PM
army_rx8
Jan 3, 2005 08:21 PM
kmg1186
Dec 12, 2004 03:44 PM
