Replacing Rear 6x9 Speakers
Old Dec 14, 2004 | 12:29 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Tomorrow I am going to replace Bose 6x9's with a pair of Infinity's 3ways. How should I go about this because the speakers that are in there now are componets, is there a crossover? If there is should I use the Bose crossover or the one that came with the new speakers?
Old Dec 14, 2004 | 12:41 PM
XeRo's Avatar
Normality is Obscene
No crossover...here's something that may or may not help you...
Attached Thumbnails Replacing Rear 6x9 Speakers-bose-speaker-placement-rx-8.jpg
Old Dec 14, 2004 | 01:14 PM
So then, what do the tweeters connect to?
Old Dec 14, 2004 | 01:35 PM
Tamas's Avatar
Registered Lunatic
I believe instead of real crossovers, there is just a capacitor for the tweeters that blocks the signal under a certain frequency.
Old Dec 15, 2004 | 01:06 AM
Here's what you should put in your RX!
http://www.pioneerelectronics.com/pn...etailComponent
Let me know what you guys think... Good idea or bad idea?
Old Dec 15, 2004 | 10:08 AM
I'm sorry, but I still feel that Infinity makes a better product. Heres what I bought. Infinity 693.5I
Old Dec 15, 2004 | 10:17 AM
No worries, very cool choice of 6x9's.
I'm curious to know how those work out because I currently have the pioneer 5 ways in my Mazda 626 & Mitsubishi Eclipse (LOVE THEM) and I was thinking of swapping them out and putting them in my RX (when I finally do get off my lazy *** and buy one)
Are you going to be adding a seperate amp?
Old Dec 15, 2004 | 10:44 AM
Nope, i'll be using the Bose amps. The stock Bose speakers are 2 ohms which means that these new speakers will only be getting half the power because they are 4 ohm. However, i'm hoping that they are at least twice as efficient (+3dB) because that would equal the power offset.
Old Dec 15, 2004 | 08:58 PM
MultiSync's Avatar
Rotary Rasp,
Let me know how these work out. Coincidently, I have the same Infinity speakers but haven't had time to put them in yet. I previously used them in my Honda and they are excellent speakers. I have always been happy with Infinity car speakers.
I believe it will be quite a bit of work to take out the rear seats and back dash in order to replace the speakers. I'll probably wait until it get's warmer outside. If you didn't know, there's really detailed instructions in the DIY section:
https://www.rx8club.com/showthread.p...ht=replace+6x9
The crossover included with the Infinity's are to separate the woofer from the mid-range and tweeter. The speaker is "bi-wired" for this crossover so there would be no reason not to use it. If you don't use the crossover, you would have to parallel connect the line to both speaker terminals.
Old Jan 28, 2012 | 05:54 PM
djdubd's Avatar
I am curious as to how the 4 ohm 6x9's worked for Rasp, or for anyone else who has tried them instead of 2 OHM.
I would really like to match the load in order to fully take advantage of the available power but the original Infinity's talked about in this thread are discontinued, as well as the ones Rasp was gonna buy.
Does anyone have a recommendation for some 2OHM 6x9's? Or has anyone had an experience (good or bad) with the more common 4OHM?
Old Jan 28, 2012 | 07:07 PM
firebirdude's Avatar
User and Abuser
Tons of people have just used 4 ohm speakers and been pleased. But if you want 2 ohm 6x9's, Infinity still makes those speakers. You're just looking at an old model number. The 693.9i is the current one. 692.9i is the 2-way version. Should run you just over $100 online. If that's too much, their Reference line is a little cheaper. Model number REF9632CF is 2-ohm as well.
Old Jan 29, 2012 | 07:42 PM
djdubd's Avatar
Thanks, really appreciate it, I had found those but only looked at them on Crutchfield's site. They wrongly listed them as 4-ohm. Should've looked at more places, I usually do as soon as I find something I want and rarely buy from them as they are more expensive on most things.
Old Feb 8, 2012 | 05:29 PM
JohnnyG's Avatar
Problem with using the stock Bose amp is that its EQ curve is matched to the speakers. Seems to be how they get so much output from cheap speakers - they are EQ'd so that the speakers stay in their "sweet spot" and don't distort. This is responsible for the signature Bose sound...aka "No highs, no lows...it must be Bose!"
rotarywanker
Dec 8, 2022 05:56 PM
MolecularConcept
Aug 1, 2015 03:15 PM
CMRine04
Jul 27, 2015 09:46 PM
Majictoast
Jul 18, 2015 06:45 PM
