Adding Oil?
Old Dec 14, 2004 | 10:24 AM
salituro64's Avatar
Adding Oil?
Do some people actually add oil after every other tank full? If I did that, I would need to use a tablespoon. I checked mine after 1K and I needed 1/3 of a quart (Not even!). I have just over 2K and still have the first quart of oil I bought. I did change the oil at 1200 and for adding I just keep 5W30 handy. It's such a small amount I do not beleive it will make a difference from the 5W20 that I use for an oil change.
Old Dec 14, 2004 | 10:27 AM
i add about 3/4 quart every 1000 miles
Old Dec 14, 2004 | 10:30 AM
Dark8's Avatar
Ride Naked!
I use about 1 qt every 3K-4K miles. I think it has alot to do with how much time you spend at WOT or high RPMs. In a month when I run two or three autocrosses my '8 can burn a quart in 1K miles.
Old Dec 14, 2004 | 10:33 AM
im always at wide open throttle...
Old Dec 14, 2004 | 10:45 AM
dmp's Avatar
dmp
RX8 and a Truk....
I can barely see my oil on the dipstick - it's the same colour AS that dipstick...I'm guessing my oil level is okay; I only have about 900 miles on the car.
Old Dec 14, 2004 | 10:56 AM
salituro64's Avatar
I noticed you can actually see the oil level better on the side without the marker line. Maybe it's just me.
Old Dec 14, 2004 | 11:19 AM
spork's Avatar
Foolio
I added a quart after 2500 miles. I could've gone longer but why wait? After about 2500 miles I was at 1/4 of the way to low. But then again, I don't WOT my car.
Why don't you just buy 5-20? Is it just hard to find for you or something? I bought a bottle of 5-30 at Target back when I was almost sure that the car might run low on oil after like 100 miles but then when I realized it wasn't nearly that bad I stopped by Pep Boys and picked up some 5-20.
And yeah for the oil stick I always check both sides of it. It's easier to see on the "back" side.
Old Dec 14, 2004 | 11:24 AM
aggietiff28's Avatar
Mean Green Keeny Machine
I think it depends on the car, how you drive it, and how broken in the engine is. Mine has 20,000 miles on it. I added about 3/4 of a quart within 3000 miles before the last oil change. Since my last oil change I have been checking it and have not needed to add any oil yet (will check again today) and it has been 2500 miles.
Old Dec 14, 2004 | 12:07 PM
salituro64's Avatar
In reference to the markers on the stick, where is the reference point for adding 1 quart?
Old Dec 14, 2004 | 01:17 PM
kdlunde's Avatar
I don't know about the exact spot for 1 quart, but according to the owner's manual (if my memory isn't faulty ), the amount between the two lines is equivalent to 1.8 quarts, so I guess that would mean add 1 quart when it's slightly less than half way between the two marks. At least that's what I've been doing!
Kern
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Tsurugi
Sep 7, 2015 08:27 PM
