LED Burnout
Old Dec 12, 2004 | 09:54 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
LED Burnout
I bought four 5LED lights from autolumination.com. After about two weeks, they all burned out. I talked the owner at autolumination and he agreed to replace them. Meanwhile, I ordered two 6LED lights for the time being and now those are burned out? Whats going on? This is getting expensive.
Old Dec 12, 2004 | 10:17 PM
GiN's Avatar
GiN
ロンリードライバー
What are you using the LED lamps for?
Although I'm sure autoillumination LEDs are properly made, you may want to add a 100ohm resistor to one of the leads coming out of the housing to limit some of the electrical current passing through the lights. While it may darken the light slightly, it should help preserve the life of the assembly.
Old Dec 12, 2004 | 10:29 PM
I'm using them as running lights.
Old Dec 13, 2004 | 12:30 AM
RX Renesis's Avatar
LED should last very very long if it's running at the rated voltage.... the only thing that can fry/burn a LED is over volting them... other than that they should last LONG...
Old Dec 13, 2004 | 12:47 AM
truemagellen's Avatar
Attracts tree branches
I have autoillumination LEDs running on the front and the back 10 all total I believe (there is one in the trunk too )
no problems...you probably put one in backwards...which is a good way to wipe them out
as for turn signals...they use little power so you need a load equalizers to stop the triple blink...I almost made a DIY on it but it is so damn easy it is almost in the tire valve cap DIY level
Old Dec 13, 2004 | 01:24 AM
How do I know what way they go in?
Old Dec 13, 2004 | 02:50 AM
DynamicDookie's Avatar
i sympathize, so far i've had two leds from autolumination burnout after 4 months. a side marker (easy), and a running light (not so easy).
any one know if these things more sensitive to environmental factors?
Old Dec 13, 2004 | 08:01 PM
I had them in my running lights in the front. One burnt out completely in about 2 mos, and the other one half burned out about a month later. Took them out...back to stock until I can get something that works!
Old Dec 13, 2004 | 08:08 PM
I'm guessing you guys damaged them while installing them...the actuall LEDs are fragile by touch so you need to hold the housing and not the LEDs while inserting them...otherwise certain death of LEDs will follow
Old Dec 13, 2004 | 08:25 PM
Can't see that...I was extra carefull when I put them in? I guess there may be some quality issues with some of them
Old Dec 13, 2004 | 11:35 PM
RX Renesis's Avatar
they ain't the fragile unless ur LEDs r extra fragile.... in ele class we chuck them abound, clamp them, break them, whatever and it still works... other than overvolting them...
Old Dec 13, 2004 | 11:36 PM
the LED itsself isn't fragile...it is the connections to the housing that is...micro soldering
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
RX8mzda
Oct 14, 2015 05:12 PM
Jazzmeson
Aug 2, 2015 09:49 PM
