calling all NAVI/Video mod experts- NEED HELP!!
Old Nov 28, 2004 | 10:59 PM
T RX 8's Avatar
T RX 8
Hey, I'm sure at least one of you can answer this question without even having to go look at your 8. I'm trying to hook up my new DVD for the NAVI (old one stolen) and ran into a problem. There are 4 connectors at the DVD player from the harness and 4 connector sockets on the back of the DVD unit. Seems easy enough except that one connector doesn't fit into any of the sockets!?
On one end (of the DVD player) there's a white 16 pin socket, white mating male connector-no problem. Next to that is a gray 24 pin socket, white male connector- no problem. On the far end, opposite the white socket, there is a square, green, 1 pin socket (GPS antenna, I think)- green male connector, everybody's happy! What's left is a silver (chrome), square, 8 pin socket about the same size as the green one. It also has 3 plastic tabs molded inside the socket (2 square,1 rectanglular), probably to ensure male connector is only inserted one way. The 4th male connector is white from a thick black wire w/red stripe and there's no way it's gonna fit the 4th socket. What am I missing? I'm thinking that 4th male connector is for grounding and gets stuck on the metal tab held on by one screw and sticking out the back between the green and silver female sockets. But then if it does, what goes in the silver socket? HELP!!
Old Nov 28, 2004 | 11:04 PM
truemagellen's Avatar
Attracts tree branches
I can help!
Old Nov 28, 2004 | 11:05 PM
ok so the black one wire is the ground and slides into the metal slot and is screwed inplace
then there is a connector that is left open...don't worry about it
let me show you something give me a minute
ok here it is https://www.rx8club.com/series-i-do-yourself-forum-73/diy-s-video-into-nav-av-electronic-video-switcher-install-44095/
Old Nov 28, 2004 | 11:06 PM
T RX 8's Avatar
T RX 8
You know, your'e the one guy I thought of first that would help. I saw your DIY for the video mod you did so you qualify as the expert I've been seeking
Old Nov 28, 2004 | 11:08 PM
ok hope things are working now PM me if you needmore help...I'll up for a half an hour longer or so
Old Nov 28, 2004 | 11:10 PM
just clicked in my head...yours got stolen? you'll have to tell us how it happened once you install the new one
Old Nov 28, 2004 | 11:11 PM
T RX 8's Avatar
T RX 8
so why is that left open?
Old Nov 28, 2004 | 11:12 PM
mr2000x's Avatar
pro_digi
can u guys watch dvd while the car is in motion not recommending it ofcourse
Old Nov 29, 2004 | 12:29 AM
that extra connector is for a wiring harness that exists for J-spec cars...it hooks up a Tv tuner and backup camera system...not a US offered accessory, besides it is 800 dollars, yikes!
Old Nov 29, 2004 | 12:31 AM
the NAVI dvd is only for Navigation
if you hookup a dvd through an av box like the one from www.rx8garage.net
you can hookup dvd players, and video game systems, etc.
as for using it while you are driving...it can be hooked up that way but the manufacturer and the seller (rx8garage) tell you not too, many times as you are taking a great risk doing so
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Patricia Odell
SE RX-8 Forum
12
Nov 14, 2016 02:40 AM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
DeltaJ802
Sep 29, 2015 01:20 PM
FubarI33t
Sep 28, 2015 08:45 PM
