SR Motorsports Hi Flow Cat Video
Old Nov 18, 2004 | 11:10 PM
foxman's Avatar
Torque is Good
Definitely louder...and I think lower...
http://indy-rx.com/videos/srcatvid.wmv
Old Nov 18, 2004 | 11:53 PM
truemagellen's Avatar
Attracts tree branches
woah you should put a warning up for that part when you do the drive by, I'm deaf now
Old Nov 19, 2004 | 12:00 AM
mysql101's Avatar
interesting clip. What exhaust did you say you had? For some reason my borla sounds a lot deeper than yours, but maybe it's the video camera.
http://tyrannical.org/rx8/borla_6k.wmv
I've been thinking about a midpipe myself.
Old Nov 19, 2004 | 12:04 AM
IZoomZoomI's Avatar
Boost needed
i think thats stock exhaust... just very clean
doesn't sound a lot deeper, maybe the vid doesn't do it justice. Sounds like a bunch of bees buzzing...
Old Nov 19, 2004 | 12:09 AM
mysql101's Avatar
oh, man. If that is the stock exhaust, i'm not going to do a midpipe. The stock exhaust is super quiet, and his setup in the video was definately anything but.
Old Nov 19, 2004 | 12:16 AM
IZoomZoomI's Avatar
Boost needed
was it that loud? didn't seem so...
Old Nov 19, 2004 | 12:21 AM
mysql101's Avatar
i think his camera doesn't pick up the sound very well. the stock exhaust is very quiet, so with the amount of noise coming from his car in this video, i can only assume an aftermarket exhaust would be way too loud with the midpipe/high flow cat.
Old Nov 19, 2004 | 12:37 AM
hamilton you have the navigation system? question is, is that Borla video yours? sounds great! I love how the exhaust pipe condenses with moisture inbetween revvings
Old Nov 19, 2004 | 12:40 AM
mysql101's Avatar
Yeah, far as I know I have the navigation, unless my damn dealer lied to me and drew a picture of a navigation unit on my dash.
anything hosted on tyrannical.org is mine
Old Nov 19, 2004 | 12:57 AM
foxman's Avatar
Torque is Good
It was my first attempt at digital video and yeah the rest of exhaust is stock. AVI, MPEG and WMV files seem to produce different sound and there are quite a few quality settings for sound and video, the camera is mono, so limiting. I will say it sounds fairly different in the flesh. I am still working to try and recreate something that seems realistic.
Old Nov 19, 2004 | 08:00 AM
mysql101's Avatar
I like Sony's HC digital video camera line. I think I paid around $350 for the one i have now (HC20). The sound is pretty accurate with it, and the video is decent. Sony has this "usb streaming" crap, but it garbles the video and sound due to the lack of bandwidth. With the firewire cable, you can get full quality digital captures without any fuss. I also had a Sony TRV unit (slightly larger body size than the HC20, but basically the same video and sound quality) which costs $200-250 (I'm going by memory, so not an exact number, but pretty close to that range)
I used to have an older video camera that cost around $700, but trying to get the output digital would be more hassle than it's worth given how cheap the new digital ones are.
Old Nov 19, 2004 | 09:15 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
I don't like the sound...I'm happy your happy, but I don't like how it sounds too much.
I like the Borla & mmmm...dang it I forgot the other name?
Old Nov 19, 2004 | 09:38 AM
foxman's Avatar
Torque is Good
I am shopping for cat backs because I want it to be lower.
Old Nov 19, 2004 | 09:53 AM
Ned M's Avatar
Sound bytes aside, what performance difference do you see with the high flow cat and stock (?) cat back, and thanks.
Old Nov 19, 2004 | 10:01 AM
foxman's Avatar
Torque is Good
SR Motorsports claims 10 HP or something like that and I think you need a less restrictive cat back to take full advantage of it which is why I want to get that plus I can probably shave a total of 30lbs off the weight with the right setup. The main thing I noticed is it seems to pull better in 4th gear from around 3K-4K rpm or so. There is no resonator and the cat is very small compared to stock and weighs some 15 lbs less.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
