TPS Light on - 300miles
Old Nov 18, 2004 | 12:26 PM
-=Zepplock=-'s Avatar
Hello all,
I have my rx8 with 300 miles only.
This morning I started the car and Tire Pressure Light was on, after 10 min ride ot turned off. The tires look ok to me. I'll check the pressure tomorrow during fill up.
Is this a normal behavior?
The outside temp was 10C this morning
Old Nov 18, 2004 | 12:33 PM
Go48's Avatar
Originally Posted by -=Zepplock=-
Hello all, I have my rx8 with 300 miles only.
Normal if your tires are underinflated. Your tire pressures were probably below the threshold when cold and as you drove they warmed up and the pressure increased to above the threshold. Check your pressures with the tires cold and set to 32PSI.
Lots of postings on this forum concerning this "issue". You might want to do some searches.
Old Nov 18, 2004 | 12:35 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Originally Posted by abbid
Its normal, when the weather is cold, the air is less dense, once the tires warm up, the light will go off.
It's normal if your tires are on the low side of triggering the TPMS... one or more of your tires are probably in the low to mid 20's PSI. Get them all up to 32PSI, and keep them there, and the light should go away for good.
Old Nov 18, 2004 | 12:50 PM
Go48's Avatar
WOW, three replies withing 9 minutes of a posting. That must be a record.
Old Nov 18, 2004 | 12:51 PM
Thank you!
This forum is da BEST.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
