The Great Renesis Porting Project!
Old Nov 18, 2004 | 11:59 PM
  #76
Snoochie's Avatar
Well what do you have to say to that RG?
I'm mega postwhoring in here but once it starts including my car I'ma postwhore as much as I want. Also did you want to do the true duel exhaust set up that RG was talking about? We could just tinker with porting first if you want pure dyno numbers and maybe go true duel later? I don't know what this involves labor and materials wise I'm just throwing ideas out there.
Also how do I measure the egt?
If you and RG come to an agreement on something I'll need to change my pants I'll be so happy. I just want this to work out in the end for the best.
And will this all help my car's lifespan cause effectively my car has to try less to perform it's normal duties? If so I'm sure me speeding all the time will negate it but it's good to know.
Old Nov 19, 2004 | 12:09 AM
  #77
guitarjunkie28's Avatar
port hacker
i don't think it will do anything to the lifespan, and not much for the efficiency, but possibly better fuel economy...but then again, possibly worse. one thing though, i'm sure it will make more power.
rg and i aren't exactly disagreeing, i think i've seen a little more in reguards to the coolant passage because i've got it right here in front of me. if he were here, he'd see it too and i'm sure we'd have a very similar, if not the same, opinion.
just so you guys get an idea of how thin that wall is--think about the intake ports on the fc's...it's even thinner than that.
Old Nov 19, 2004 | 12:10 AM
  #78
port hacker
you know what i really like about this is we're both voicing opinions in a respectful way--and even if we do disagree on anything, we're not stepping on eachothers toes or trying to cut eachother down. try getting that on some of the other forums!! :D
Old Nov 19, 2004 | 12:34 AM
  #79
Snoochie's Avatar
Man try getting that on this forum sometimes. No j/k. This whole thing is awesome and I'm very lucky to be a part of it. What do you think about the dual exhaust also?
Old Nov 19, 2004 | 12:44 AM
  #80
port hacker
i think he's got an awesome idea there and i'd definately like to try it--just not on this round. i think that may be just a little more work than i want to do for free. lol
Old Nov 19, 2004 | 12:53 AM
  #81
rotarygod's Avatar
Here is a crude outline of where I'd want to run the exhaust port to. How are you hitting water if you aren't going any larger than this. Take a picture of it somehow.
Old Nov 19, 2004 | 01:19 AM
  #82
port hacker
because the coolant passage actually does this:
Old Nov 19, 2004 | 01:23 AM
  #83
rotarygod's Avatar
I got ya now. I would probably only port it up to that point and not past. spend alot of time cleaning up the inside edges. I'd do this on the first one and then maybe get more extreme in the future. I'll probably just have to spend the money and buy a housing so I can port one and make my own templates.
Old Nov 19, 2004 | 01:26 AM
  #84
port hacker
this is actually a tad bigger than the actual port... keep in mind i port better than i draw.
if you notice the "red zone", that's where the leading edge of the rotor passes by the port. i kept material there to make sure the side/corner seal junction was supported throughout its journey through the engine.
hope this clarifies it a little more.
Old Nov 19, 2004 | 01:29 AM
  #85
port hacker
when you bevel the edge, you can actually get a pretty hefty radius on it--just can't do much along the vertical axis without hacking into it. seriously, it's about 1.2-1.5mm thick...optimistically
Old Nov 19, 2004 | 12:07 PM
  #86
port hacker
so the port ended up a bit narrower than i'd like, but i'd rather have the side/corner seal supported. taking that corner out wouldn't be any big hp improvement over the way it is, so better safe...
Old Nov 19, 2004 | 03:48 PM
  #87
Snoochie's Avatar
Alright this all sounds awesome. Inluding being safe with the side seal because that seems to be the part where everyone doesn't wanna screw with. I was just tossing ideas out there before. But, if this porting works out well I'd be more than willing to pay for the true duel exhaust of course :D
Old Nov 19, 2004 | 04:40 PM
  #88
port hacker
any possibility of making it up to my house this weekend to look at the one that's almst done and maybe shoot off some pics?
Old Nov 19, 2004 | 05:32 PM
  #89
Snoochie's Avatar
I work later today 4pm-10pm, 2marow 6:30am-2:30pm (Nordstrom)/3:00pm-10:00pm (Pick Up Stix) and Sunday from 10am-10pm..ahh the life of a student trying to afford gas. I could go up there saturday night if you have enough lighting that late, or monday I'm outta class around 1ish and I have the rest of the day free so we can try and do that? I'm sure we'll get something soon.
Old Nov 19, 2004 | 06:14 PM
  #90
RX3+5's Avatar
Bullshit Detector
Nice information. Keep up the work!
Vince
Old Nov 19, 2004 | 06:44 PM
  #91
port hacker
i think we'll start a new thread once it gets under way--just so people that wanna see don't have to flip through hundreds of posts...
i'm expecting good results. nothing dramatic, but a nice solid gain across the rpm band.
Old Nov 19, 2004 | 06:49 PM
  #92
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
That sounds good to me, considering we can't get a lot of the across the band power. Most of the bolt-ons add a few hp to the top end, after 7k rpm or so. Good luck.
Old Nov 19, 2004 | 07:13 PM
  #93
port hacker
i'm looking for solid, duplicatable results as opposed to just the end number.
Old Nov 19, 2004 | 08:06 PM
  #94
Snoochie's Avatar
Man I can't sleep I so want this like yesterday
Old Nov 19, 2004 | 08:19 PM
  #95
G8rboy's Avatar
Mmmmm... Rotary Donut
... that makes two of us Snoochie Boochies! :D
Old Nov 19, 2004 | 09:21 PM
  #96
port hacker
i'll warn the rest of you that if this pans out, look for the porting cost to be relatively high--as it's about 5 times the work of the rx7 motors!
but ther than some very minor cleanup work, the first one is DONE! :D
Old Nov 19, 2004 | 09:28 PM
  #97
nhk's Avatar
nhk
can not wait to see the dyno results.
Old Nov 19, 2004 | 09:31 PM
  #98
BaronVonBigmeat's Avatar
Senor Carnegrande
Cannot wait to see some track results. :D
I can understand not wanting to totally punish your car though. Isn't there some sort of standard 5-60 "rolling start" test the magazines do? Basically so you don't trash your clutch and transmission.
(and Vince, weren't you banned?)
Old Nov 19, 2004 | 09:41 PM
  #99
port hacker
it's be great to get all the performance specs with and without the porting. i think the most important thing of all is going to be snoochies butt-dyno. how does it feel? how do you like it? etc etc.
i guess time will tell. as long as i've got nothing to do when he drops the irons off, it should be a one day turnaround-maybe 2. now it may take up to a week if i'm busy, but i'm anxious to get it done ASAP!!!
Old Nov 19, 2004 | 09:48 PM
  #100
Snoochie's Avatar
Yup yup. Should I get my brother or someone to drive up with me just in case I need to leave it there over night or for an extended period?
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
