View Full Version : Steering wheel extension?
Rotary Titus
11-13-2004, 02:05 AM
Anyone know if those made by momo or sparco fits on our stock steering wheel? Like it's a piece that fits between the hub and the steering wheel so it extends it towards the driver. I find my wheel too far out and would like to extend it (WHEN is mazda gonna have tilt and telescopic function??).
Mikelikes2drive
11-13-2004, 05:28 AM
that would be awesome if it did fit... hmmm someone should find out
shawrf1
11-13-2004, 06:57 AM
The steering wheel spacers made by sparco/momo will not work with the stock steering wheel; to use them, you'll need an aftermarket steering wheel.
Rotary Titus
11-13-2004, 11:02 AM
dang... I see.... I wanna keep my steering wheel controls!
so our stock steering wheel is a different "bolt pattern" or something?
Groo
04-22-2006, 12:31 AM
ok, I'm bumping this thread to see if anything has developed in the last 1.5 years- any way to extends the stock steering wheel yet?? :-)
juikster
04-22-2006, 12:43 AM
Yes, there is a new product out that could give you a few more inches.....hmm, I recall Austin Powers displaying one that he thought worked for him....half way :)
Groo
04-22-2006, 06:34 PM
Excellent.. I can't seem to locate the user you are referring to, happen to know what their exact forum name might be?
Groo
04-28-2006, 10:41 PM
Still looking for some info :confused:
Easy_E1
04-29-2006, 02:59 AM
:Eyecrazy:
:spank:
:banghead:
:uh:
NgoRX8
04-29-2006, 03:01 AM
... it has up and down tilt. what other tilt do you need?
Groo
04-29-2006, 10:54 AM
Extension towards the driver.
DOMINION
04-29-2006, 02:43 PM
You must have short arms :mdrmed:
Groo
04-29-2006, 04:42 PM
I have to sit with the seat reclined quite a bit to give myself enough headroom in the car. . things would be a bit more "comfy" if the wheel could pull a little closer.
04Green
03-04-2012, 12:43 PM
Multi-Year BUMP!
Problem still exists. Issue is head room with helmet. Lowered seat thread solves a bit of it, as well as sliding the seat back. Now it would be nice to have wheel closer for track work.
dannobre
03-04-2012, 12:48 PM
I just installed an aftermarket hub and wheel...but you loose everything but the horn....and in order for the steering angle sensor to work properly you have to make an adapter that requires some Fab skills. It is not an easy thing to get working properly. Thnking about getting a few of the adapters made? Dunno if they would sell though.
It would be much easier to correct your seating position than to get this to work...
YaXMaN
03-04-2012, 12:53 PM
http://curiousinkling.com/~shirt/_design/t-rex-shirts.gif
04Green
03-04-2012, 05:56 PM
@dannobre
Seating position will not help any more. Issue is power seat + sun roof +helmet. To get butt to top of helmet distance correct, even with lowered seat, I need to be farther back, or cannot really reach the wheel. If I slide butt forward, and crouch down, knees hit dashboard.
I am going to try tearing seat out again, and see if I can get at foam. From what I could tell last time though, the power seat foam is all in one piece.
Thanks for the heads up on the steering angle sensor.
dannobre
03-04-2012, 07:01 PM
Might need to go with a racing seat and custom bracket to get yourself into a decent position :(
...there is room there for 6"4ish in a custom setup with lots of room.........
Bladecutter
03-04-2012, 09:11 PM
And that's the reason why I chose the Sport over the GT when I bought mine this time last year. Nothing beats that several extra inches of headroom when you've got a helmet on, and you're over 6' tall.
I do hope you are able to solve your steering wheel dilemma.
BC.
monchie
03-04-2012, 10:04 PM
This thread is alive again! Anyway, i never heard of a steering wheel extension. Why not just move the chair forward so that you could reach it and drive it comfortably...just sayin'
EricB
03-04-2012, 10:19 PM
@dannobre
just making sure you saw this:
http://www.rx8club.com/showthread.php?t=205255
YaXMaN
03-04-2012, 11:48 PM
Did you just tell him to go look at a thread that he himself started?
EricB
03-05-2012, 02:35 AM
:pat::pat::pat::pat::pat::pat::pat::pat::pat::pat:
I remembered seeing that a long time ago, i didnt even bother to check.... but if anyone was curious what he was talking about.... lol
