RX-8 Carputer @ SEMA
Old Nov 9, 2004 | 04:21 AM
shawrf1's Avatar
RX8-less
The stanchions surrounding this car probably kept people from seeing it, but the molded console monitor and keyboard are intriguing...
Old Nov 9, 2004 | 08:52 AM
devoid's Avatar
My doctor prescribed RX-8
Couple of things...
Looks great...a lot like my car, except I have more screens integrated, including the original NAV screen and I have a trackpad integrated into the center counsel. Also, my keyboard hides under the passenger seat...a few things they should have considered.
I really love the seats though. Makes me consider upgrading mine.
1 beef though, why, if they upgraded the seats and belts with racing harnesses, didn't they remove the original front seat belts?
Old Nov 9, 2004 | 11:19 AM
truemagellen's Avatar
Attracts tree branches
great point about the factory seat belt...probably the seat are there just for the show anyhow...the factory ones, which are very nice will be put back in (maybe cause the factory ones were leather)
Old Nov 9, 2004 | 12:11 PM
Sputnik's Avatar
Originally Posted by devoid
...1 beef though, why, if they upgraded the seats and belts with racing harnesses, didn't they remove the original front seat belts?
Because those racing harnesses aren't really street legal. Besides, it looks to me like the shoulder harnesses are mounted at the bottom of the seat itself (check me if I'm wrong), and even if you assume that they are mounted correctly (with the right hardware, to strong enough positions), that is an incorrect mounting of those seat belts. And, shoulder harnesses in a car w/o a rollbar can be a liability instead of a help in some situations.
I don't mean to come off as some kind of snob, but like everything else in the aftermarket biz, there are those who put some good thought into what they do, and those who simply slap things on. And if I were in that car, I'd be putting on the factory belts insted of those racing belts.
---jps
Old Nov 9, 2004 | 12:33 PM
yo shaw..this the same 8 as the jadatoys 8??
Old Nov 11, 2004 | 03:12 AM
DOMINION's Avatar
I don't buy Kool-Aid
I seen this 8 and I have video and picks of it inside and out. Its OG paint is black and was painted dame good to look like this. Just one thing you cant see that good in the pick that I will put in red here is the BIG gap...
Old Nov 11, 2004 | 10:26 AM
swift21's Avatar
yeah the car was rushed for sema and is being re-done right now. it wil look pretty clean once its done. Thanks for all the love guys this was the jada rx8 & its now the hotwheels rx8. as soon as the car is completely finished i will get you guys some pics so you guys can give me some feed back. THANKS!
Old Nov 12, 2004 | 02:02 AM
DOMINION's Avatar
Wow hotwheels!... Well here are some more and a good inside pick.
Old Nov 12, 2004 | 07:50 AM
huhsler's Avatar
This may be a silly question, but where would you load a CD or DVD in this setup?
Old Nov 12, 2004 | 07:53 AM
RXE16T's Avatar
'RX-EIGHT'
The actual CD/DVD unit has probably been relocated to the glovebox or the trunk.
Old Nov 12, 2004 | 07:56 AM
devoid's Avatar
As for the belts....I think the shoulder harnesses are proper. They go through the seat to be bolted down under the rear seats. This is typical.
As for loading CD/DVD....good question...glove box? trunk changer?
Old Nov 12, 2004 | 09:36 AM
swift21's Avatar
actually the car has a PC that is mounted on the right side of the driver seat.
Old Nov 12, 2004 | 10:29 AM
DOMINION's Avatar
Old Nov 12, 2004 | 10:43 AM
Intrigue 8's Avatar
"dude your getting a dell"
Old Nov 12, 2004 | 12:57 PM
Sputnik's Avatar
As for the belts....I think the shoulder harnesses are proper. They go through the seat to be bolted down under the rear seats. This is typical...
Just because it is typical, doesn't make it right. Check the rules for shoulder harness attachment height in racing sanctioning bodies. There is a minimum angle that the shoulder harnesses can sit. Lemme 'splain why.
Take a look at the attached sketch, which is a very basic view of the shoulder harness from the side. Take a look at the top two drawings. When the car goes through an impact, the mass of the occupants body is thrown forward. While even racing belts stretch a little under such a load (remember, there are many variables, but literally thousands of pounds of stress can be generated by even a 30 mph accident), it is very little. Take a short piece of string, and put on a table in a similar upside down "V" shape. While holding the ends in place, simulate a body leaning forward by pushing that part of the string out, and as the "front" of the string pulls forward, the top of the striing is pulled down. The same thing happens to a shoulder harness. As the body pulls forward, the belt is pulled down.
The lower left drawing is arranged similar to shoulder harnesses mounted to the seat bottom, with the angle of the belt around 90 degrees. As a body is thrown forward, that shoulder harness pulls straight down (with the same force as the body is moving forward, which can be immense), and your body will give before the belt. Collar bones have been snapped, spines have been crushed or broken). There have also been extreme cases where some people have had minor back and shoulder injuries simply from hard braking forces and improperly mounted belts. This is not theory, this has happened. The lower right drawing is arranged similar to a recommended angle of 45 degrees or less (the resulting angle is important, not the height). With this angle, the direction of the force is no longer directly down, it is more towards the rear and back. With the same force, much less damage will occur. Even less damage will occur with a 30 degree mounting angle. Try this with the string experiment, and you will see that the distance the string moves down will be very different between the different mounting angles.
That is why that mounting location for the shoulder harnesses is not proper.
---jps
Old Nov 12, 2004 | 02:41 PM
webba_az's Avatar
Not a mid-life-cricer
Agh.. seeing this just makes me even more angry that NO ONE has come up with a solution for replacing the stock stereo (or even locating a replacement elsewhere) aside from the $500 rmagic solution.. this makes me a sad panda
Old Nov 13, 2004 | 01:40 AM
DOMINION's Avatar
Give it time man...
Old Nov 13, 2004 | 04:18 PM
Omicron's Avatar
OOh, I'm likin the look of this... can't wait to see it when it's finished. Now what they need to do is (a) make it touch screen integrating the audio and the carputer, and (b), make it work with the steering wheel controls.
Old Nov 13, 2004 | 11:55 PM
DOMINION's Avatar
Yea or how they got the computer in the drivers seat? How they do that?...
Old Nov 14, 2004 | 02:54 AM
Mikelikes2drive's Avatar
it would be a pain to switch radio stations unless its touch screen or sumptin... but it looks clean!
Old Nov 14, 2004 | 03:01 AM
its touch screen I thought...but to tell you the truth it is seriously fugly...
Old Nov 14, 2004 | 06:39 AM
DOMINION's Avatar
Originally Posted by Omicron
OOh, I'm likin the look of this... can't wait to see it when it's finished...
Old Apr 15, 2009 | 11:05 AM
niv-nav's Avatar
hey ive seen one which they put in the sun glasses holder lik a little head unit if that helps
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
arexatemate
Oct 9, 2015 06:23 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
