Bad news about UR pullies...
Old Oct 31, 2004 | 01:11 AM
BLOWN8's Avatar
On friday when i went to UR to get the pullies they just got the shipment of them and i waited for the engineer to double check the pullies to make sure they are good, they were and i took them home they looked great as far as i can see.
Saturday morning i went to put them on, took out the intake system and took off the water pump, then the crank pully. When i went to put the crank pully on i was able to put two of the bolts in but not the other two, after attempting a couple of times i took out the UR pully and matched it up the the stock one and the two of the UR holes were the bolts go through are off like 1 cm!!
Now i have to wait till monday to see what UR is going to do about this, and if all there pully's have this defect?
Old Oct 31, 2004 | 01:42 AM
RXE16T's Avatar
'RX-EIGHT'
Did you check they gave you the right application?
It's not for a FD or something is it?
Hard to believe that they would overlook something like this throughout the entire r&d and manufacturing processes.
titaniumgrey's Avatar
18 year old speed freak
**** ...... are you kidding me ? Are you sure you got them alligned correctly ? That is a huge mistake ffrom UR .....
Old Oct 31, 2004 | 01:52 AM
wakeech's Avatar
mostly harmless
not too huge a deal, send them back because they obviously don't fit.
i too would tend to lean toward them being for the wrong car, some kind of mixup or something liek that.
Old Oct 31, 2004 | 01:56 AM
BLOWN8's Avatar
Yes they gave me the right application, i sat at UR for a half and hour as the egineer went over the pullies to make sure they were good.
Every thing was alligned correctly I triple checked everything, i marked also the UR pully were the holes should be to show them on monday.
Old Oct 31, 2004 | 01:32 AM
rotarygod's Avatar
On the RX-7's, the pulley only fits one way. The 4 mounting holes are not perfectly spaced and you have to rotate it until it fits right. This way you can't put it on wrong. If you do install it wrong, the timing marks don't line up. There are only 4 ways you can rotate it. See if they just put the timing marks on the wrong face.
Old Oct 31, 2004 | 06:11 AM
Richard Paul's Avatar
As I understand it ONE hole is off so you can't get the timing disc on wrong. So you should not be able to get two bolts in if you are wrongly timed.
Still I'd look at that before I sent them back.
It's not like the 7, here there are four parts. The hub, the timing disc and two pulleys.
Not that I have ever seen one.
Old Oct 31, 2004 | 02:06 PM
rotarygod's Avatar
The concept is still the same Richard. There's only 1 way the holes line up.
Old Oct 31, 2004 | 11:00 PM
BLOWN8's Avatar
theres only two different ways that you can rotate the pulley to put it on, and i matched up to the stock pulley in every combination possible.
I'll let u know what UR says.
Old Nov 1, 2004 | 10:58 PM
Never buy anything from UR.
I've read several problems with people receiving the incorrect pullies from UR.
Old Nov 2, 2004 | 01:16 AM
BLOWN8's Avatar
Went there today, and got a new crank pulley went on easily and car runs great. Will post dyno results in a few days
Old Nov 2, 2004 | 01:40 AM
RXE16T's Avatar
'RX-EIGHT'
So did they admit to giving you the wrong one?
Old Nov 2, 2004 | 09:13 AM
QuarterMile's Avatar
There you go, that's a good choice... Like no one else has problems. What would you say to someone if they said "I'm not buying an RX-8 becuase they have too many problems with their drive train"? But, that's just my 2 pennies.
Old Nov 2, 2004 | 06:47 PM
BLOWN8's Avatar
They didn't admit to giving me the wrong one.
Old Nov 2, 2004 | 07:11 PM
Icemastr's Avatar
So if the one you had wasn't the wrong one why did they give you a different one?
Old Nov 3, 2004 | 08:20 AM
BLOWN8's Avatar
the holes were off on the one i had, but the new one the holes were not. I think the one i had was a defect.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
duworm
Oct 1, 2015 04:57 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
pjwermuth
Sep 28, 2015 11:36 PM
