Changing out H9 high beams...?
Old Oct 29, 2004 | 09:45 PM
Art Hazebrook's Avatar
I've searched till I'm blue in the' face...is there a thread that gives some pointers on changing out the H9 high beams?
Thanks in advance!! Art :D
Old Oct 30, 2004 | 08:21 AM
tpryor's Avatar
I can tell you this - the service manual recommends you go through the inner fender. When I changed mine, I thought "I can get my hand in there, I'll just do it from the top".
Short version - if you are VERY patient and have small hands, it can be done from the top. Once I realized I have neither trait (especially the patience part), I took about three of the fasteners loose from the fenders and had them both changed in minutes.
You'll be surprised how easy it is.
Old Oct 30, 2004 | 10:50 AM
subduedracer's Avatar
Realtor1
Can you take the head light assembly out without taking the bumper off?
Old Oct 30, 2004 | 11:30 AM
Taking the bumper off was one of the results of my search and I thought ...NO WAY !!! Besides, if you look at the pics...you still gotta get behind the headlight assembly once the bumper is off.
tpryor thanks for the tip!!
Regards, Art :D
Old Oct 30, 2004 | 01:34 PM
tpryor's Avatar
There are a couple of hidden bolts on a bracket that runs downward from the outside edge of the headlight assembly. If you were looking to remove the entire headlight assembly, you would have to take MOST of the front end off (within a few screws).
I've had mine off twice now, it's not that big of a deal. Figure about 30 minutes off and back on, plus whatever work you are doing.
SO, the answer is "probably", but you might as well take the whole bumper off.
Old Oct 30, 2004 | 03:10 PM
StealthTL's Avatar
Metatron
It HAS been done....
I have changed both the left and right bulbs thru the top.
You take the fuse cover off, and on the passenger side you take the ECU cover off.
Still WAY easier than removing the bumper!
(I changed the H9 for those 'blue' 80watt ones - I swear it got DARKER with them on! Back to stock now!)
S
Old Oct 30, 2004 | 10:00 PM
Went in from the fender well...after removing the wheel there were 5 quick release bodywork connectors holding the fender well moulding in place. Pulled those and it took about five minutes per lamp...much easier than trying it from the engine compartment!!
I installed "Farenheit" 65W Super White Halogens...and saved the stock bulbs just in case... :D
Update: the "Farenheits" seem to be a tad brighter and match the HID's much better than the stock units. I'm happy!!
Thanks for the replies, Art
WranglerFan
May 31, 2022 07:51 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
fistofmeat
Oct 7, 2016 12:15 PM
XianUnix
Sep 29, 2015 03:48 PM
