A/F ratio plots - normal?
Old Oct 24, 2004 | 06:10 PM
bxb40's Avatar
Rotary Newbie
Question A/F ratio plots - normal?
I pulled the A/F numbers out of the ECU and plotted them in Excel. Seems that my engine likes to sit a lot at 14.7 and 15.0 (the first statistical freq. plot). The second plot is RPM versus A/F.
Anybody else did these plots? I have the A/T RX-8, hence my RPM values.
Attached Thumbnails A/F ratio plots - normal?-obd2%5B1%5D.jpg
Old Oct 24, 2004 | 06:19 PM
mysql101's Avatar
your car will do that in closed loop.
When logging data, delete anything under 5000 rpm to prevent it from poluting your information.
Old Oct 30, 2004 | 05:12 AM
sco's Avatar
sco
Or capture the fuel system status and remove anything that is logged when the status is "closed" (i.e. closed loop)
Old Oct 30, 2004 | 07:22 AM
Rasputin's Avatar
Interesting, and normal.
Can't you collect and plot WOT curves instead of random running involving close loop?
What 'tool' did you use? Or did you connect directly to the lambda sensor?
Old Oct 30, 2004 | 11:58 AM
bxb40's Avatar
Rotary Newbie
I used the CANScan tool, then got the file in Excel. I'll try other values combo, see which ones looks best. Thanks everybody for your suggestions!
Old Oct 30, 2004 | 12:24 PM
Rasputin's Avatar
These are curves I measured using the (still in development) Hymee CAN OBD tool. It's WOT data taken during an accel from 4000 to 7500 rpm (Std Power, sorry!).
It clearly shows the trend of massive overfuelling to maintain an acceptable cat temperature (approx 960°C).
Attached Thumbnails A/F ratio plots - normal?-run1.jpg
Old Nov 10, 2004 | 01:28 PM
davefzr's Avatar
Does the closed loop cycle end at 5,000 rpm? Can this be changed with tuning software and or would you ever want to?
Why not just keep the closed loop on all the time since it automatically trys to meet the optimum AFR based on the sensors?
Is it because of this?
Under increased engine load the optimum air/fuel ratio is richer than the stoichiometric air/fuel ratio in order to give maximum engine output and prevent engine damage.
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Vedivan1
Sep 18, 2015 12:39 PM
