Oil Filter/Oil change Question for the experts
Old Oct 15, 2004 | 11:19 PM
EandGWZ's Avatar
Just wanted to thank everyone for the great hints/directions/best practices for DIY oil change for the 8.
Quick question! I changed my oil and could not get the filter off (wrong adapter). To make a long story short I changed the oil and left the old filter on.
I now have the right tools...Can I still change the filter with the oil level at full?
Thanks in advance. Worst case senario I'll just wait 3000 miles and do it the right way the next time.
Old Oct 16, 2004 | 12:37 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Yes... you can ( I did this with my Miata a couple times since I was running synthetic oil (2 filter changes : 1 oil change)). You'll probably get some spillage though... I would think opening the oil fill cap might help equalize that some. Not sure if you saw my tip on that, but a diaper wrapped around the filter base can really minimize the mess. Also, even with the right adapter, you might want to try a bit of sandpaper on the inside of the filter wrench for this first one... it's on crazy-tight.
Old Oct 16, 2004 | 02:34 PM
EandGWZ's Avatar
Wink
I followed your DIY instructions to a tee. The results regarding post oil change---filter change. Woke up this morning wrapped the bottom of filter with heavy duty kitchen paper towels and probably only an ounce or so came out of the filter. The operation was a success!!!!
Old Oct 16, 2004 | 03:28 PM
yamajj's Avatar
i changed my oil last night and i was amazed at how easy it was. the only reason i needed to lift the car on the jack was to get the drain plug back on with the correct torque value.
thnx mazda for making this an easy job. :D
yamajj
05TR1CH
Apr 18, 2023 04:56 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Skyl3r
Dec 2, 2019 04:51 PM
uZu
Dec 30, 2015 12:35 PM
MolecularConcept
Aug 5, 2015 04:43 PM
