Trunk wont open!!
Old Oct 8, 2004 | 09:06 PM
eMOOtional's Avatar
Angry Trunk wont open!!
i recently got my RX-8 and i found out that the trunk button doesnt work? also i cant open my trunk with the remote?? Am i just pushing the button wrong in the car or did any of this happen to any of yall at the beginning?? I can only open the trunk with the key.
Old Oct 8, 2004 | 09:12 PM
Gomez's Avatar
Shifty Bastard.
There is a remote disable button inside the glove compartment......push it.
Gomez.
Old Oct 8, 2004 | 09:13 PM
JM1FE's Avatar
1. Open the glovebox
2. Locate the button that enables/disables the trunk solenoid
3. Push it.
4. Test the remote.
If it works, RTFOM - there's lots of useful info in there.
If it doesn't work, it's under warranty, see your dealer.
Old Oct 8, 2004 | 09:36 PM
eMOOtional's Avatar
thanks guys it worked. u guys were great help
Old Oct 8, 2004 | 11:16 PM
rotten42's Avatar
Mentalhealth is overrated
3. Push it.
4. Test the remote.
I am an older fart and don't know most of the Acronyms but RTFOM is funny!
LOL
Old Oct 9, 2004 | 03:13 AM
Gomez's Avatar
Shifty Bastard.
Cheers...
Old Oct 9, 2004 | 10:33 AM
JM1FE's Avatar
LOL
http://www.catb.org/~esr/jargon/html/go01.html
Old Oct 9, 2004 | 03:00 PM
Katchoo's Avatar
Next time that happens, grab your hatchet and start whacking away at it. At some point the trunk will open and your problem will be solved.
Old Oct 9, 2004 | 11:30 PM
VooDoo's Avatar
Cool Ha Ha Ha!!!!
3. Push it.
4. Test the remote.
Thanks for the late Saturday laugh! At least he was able to diagnose and fix the problem without an embarassing trip to the dealer...
Old Oct 25, 2017 | 06:20 PM
warchild2316's Avatar
Im a new member but have been reading the threads here for months, many issues resolved thanks to you guys but still chasing down the trunk release issue. 2 questions. #1 Where and which relay is the trunk release relay and #2 how can I test/bypass the glove switch. I have an 04 GT. I have already checked and exercised the glove switch and replaced the trunk actuator. Still hear the click upon request, but no release by either the trunk release switch under the steering wheel, nor the key fob. My only access to the trunk is the key. All other functions work perfectly. Love my 8 and have restored it 99.9% but this last issue is being difficult. Suspect the glove switch is bad but dont know for sure. Any help would be appreciated. Thanks.
Old Oct 25, 2017 | 06:42 PM
boricua13's Avatar
Rican
Holy revival......
Try this
https://www.rx8club.com/series-i-tro...please-266175/
Old Oct 25, 2017 | 06:53 PM
BigCajun's Avatar
Originally Posted by boricua13
Holy revival......
I appreciate new guys not starting another thread.
Old Oct 25, 2017 | 06:57 PM
Boricua13 thank you!!! This is exactly what I was looking for. Thought the relay was under the hood. You are awesome, will keep you posted. Won't get to it till this weekend but 99% sure this is the culprit.
Old Oct 30, 2017 | 09:40 AM
TheKDog's Avatar
2007 BB RX8 GT
What's the fix for an '07?
There is no button in the glovebox.
Old Nov 7, 2017 | 05:06 PM
Got it!!!
Boricua 13 thank you!!! I searched high and low to find that relay, but that diagram got me where I needed to be. Bothe the trunk button under the dash and the key fob open the trunk again. Wish I would have tested the relay before I spent $30 on a trunk actuator, but hey my 8 is 100% restored now. Thanks guys for all the helpful threads. I repaired 90% from the information in this forum.
Old Nov 7, 2017 | 05:14 PM
Only 2 components left then; trunk actuator and relay. My advice, test the relay first, it cost about $20 for the relay and $30+ for a used trunk actuator. So read the post by Boricua 13 and test the relay first. If the relay works, you can pick up a trunk actuator off of Ebay or hmu cause I just bought one and didn't think to test the relay first so I'm rockin' a spare.
Old Oct 6, 2018 | 09:11 AM
spoddyandthemazda's Avatar
GoSpoddyGo!!!
Thanks for posting your advice as it was indeed my trunk relay which was broken. Bought a used one and popped it in and the trunk lid is opening with interior and key fob release buttons.
So good to have it working again, very tricky to get the relay out as on RHD cars its right beside the throttle pedal.
But having your trunk or boot as we call it in the UK, working again is great, was living with using the key to open the trunk for over a year.
Old Oct 7, 2018 | 11:55 AM
mazdaverx7's Avatar
RX-Heaven
Nice job searching and getting the issue solved! I have heard of that relay failing here and there and now that our cars are getting older, its good that this info is still out there
Old Aug 22, 2020 | 04:15 PM
Thomas Marvin's Avatar
Foun
Gomez.
Found it. Thanks to this forum
Old Feb 15, 2022 | 02:12 AM
RedrayL's Avatar
Did you just pull the relay out or is there a latch you have to release.
Mine is slightly mobile and difficult to get hands in to access properly.
Any advice welcome.
Old Feb 17, 2022 | 09:39 PM
the on/off Valet button in the GLOVEBOX was only on the 2004 and 2005 models, there is also a relay that can cause this problem if it fails
https://www.rx8club.com/series-i-tro...8/#post4871807
hope this helps …
Old Feb 18, 2022 | 01:10 AM
RedrayL's Avatar
Thank you for the reply,
The valet button is working.
I think my problem is with the relay in the right side of the drivers foot well
However, I didn't want to pull too hard on the relay before checking that was the correct way to remove it. I know that some relays have a clip or some other retaining device but unfortunately I am not flexible enough to see if one exists in that particular position. In fact, I can only just reach it with one hand.
I would appreciate it if someone can confirm there is no latch of any kind and I will get back to it with more confidence that I'm not going to break something.
Regards,
Ray
Old Feb 18, 2022 | 02:01 AM
did you not open and read the link I posted in the previous reply?
Fixed it.
The issue is the trunk B110 imasen relay under the dash in the footwell area, for RHD cars near the throttle pedal.
For LHD it is in the passenger area near the fuses.
Took some fiddling about with a screw driver to get the relay out but bought a used relay and popped it in,
most relays simply push in/pull out of the contact block
mopiko
Sep 12, 2022 03:56 PM
kosoku
Nov 1, 2009 08:57 PM
blowinup
Jul 30, 2009 10:11 AM
belly
Jun 29, 2008 07:00 PM
