wheel width/offset
Old Oct 7, 2004 | 09:47 PM
BIU's Avatar
BIU
wheel width/offset
Our stock setup has 18x8 and an offset of 50 right?
Would a set of 18x7.5 wheels with a 43 offset fit on the 8s with no problems?
Old Oct 7, 2004 | 09:55 PM
Napboy's Avatar
Sho'Nuff
it all depends on the wheel design. as long as it clears the caliper, it should fit just fine. i'm not sure why you'd want a thinner wheel though. That smaller offset will not make the wheel "stick out" much farther than stock because the wheel is only 7.5" wide. make sure the bolt pattern will fit the 8 also. good luck.
Old Oct 7, 2004 | 10:35 PM
BIU's Avatar
BIU
reason is because im in love with these wheels :D
https://www.rx8club.com/showthread.p...d=1#post557386
Will these fit no problems?
Old Oct 8, 2004 | 01:37 PM
Napboy's Avatar
Sho'Nuff
looks like they should fit just fine.
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
