stalling out in 3rd and in 4th with clutch in ....
Old Oct 5, 2004 | 02:58 PM
titaniumgrey's Avatar
18 year old speed freak
Well this sounds weird. ... my car idles fine and drives fine and everything, but when I go on the highway or drive normal and take a turn and go from 4th down to 3rd and hold my clutch in , my revs bounce ...... weird. Usually it stalls too so I have to start it up once again. weird .... anyone know whats the problem ? It only seems to happen in 3rd and 4th with clutch all the way in. If the revs drop under 1000 rpm it just bounces and bounces and then stalls out. I'm very frustrated, X28 told me it mite be the battery loose , already tightened it and still no luck. Anyone know ?
Old Oct 5, 2004 | 03:21 PM
brothervoodoo's Avatar
RainMan is Back
Do you still have those problems after yanking the intake and CZ?
You flooded it right? Did they clean and/or or replace the plugs?
Old Oct 5, 2004 | 03:38 PM
they said they replaced the plugs , but i dun believe em, intake is in , cz is out
Old Oct 5, 2004 | 07:05 PM
Hmmz , weird tested it again today. .. only does it in 3rd and 4th gear , doesn't do it in 1st or second .... guessing something is wrong with the syncros ? cause i think its trying to rev match or what ever its called ... then it stalls ...
Old Oct 5, 2004 | 07:07 PM
Nvm .. I think I found the problem. ... the amp has a offset light on .. maybe it's draining the power .... disconnecting it and will test my theory tomorrow .. sleep for now ..
Old Oct 6, 2004 | 01:16 PM
errr... crap , I think I found the problem , it's the negative side , it's loose , anyways, what tool do you guys use to tighten it ? I tried pliers but it didn't really get it tight without stripping some metal. and a socket wrench won't fit 8/
Old Oct 6, 2004 | 01:18 PM
guy321's Avatar
Humpin legs and takin nam
on the battery? 10mm socket or box wrench.
Old Oct 6, 2004 | 01:19 PM
errr , what if its in already , hard to explain , like I need a longer socket.
Old Oct 6, 2004 | 05:44 PM
w0rm's Avatar
PUSHER ROBOT
extended socket...
Old Oct 6, 2004 | 07:27 PM
dang , shoulda read it earlier .. did it the hard way .... pliers >< lol, anyways, if anyone ever runs into this problem X28 is right, its the battery
theblinkof
Oct 4, 2023 05:24 PM
tbiggybig
35
Jul 14, 2022 06:14 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
