View Full Version : Spark Plug Gap
HERO
09-14-2004, 12:42 AM
Hey guys, I was wondering what effects would be created by changing the spark plug gap. Leading plug... trailing plug(or whatever they are called)... i'm not too firmiliar with the rotary design :confused: . Has anyone tested any different gaps?
ZoomZoomH
09-14-2004, 02:59 AM
can you even gap a rotary engine spark plug??? there's no 'tip' to adjust it... it should come pre-adjusted ready for use...
HERO
09-14-2004, 09:00 PM
ah i see, like i said im a rotary noob :o
MyRxBad
09-15-2004, 10:08 AM
The gap comes preset from NGK. I wouldn't mess with the gap because if you open it up too much you could end up taking out your apex seals.
ZoomZoomH
09-15-2004, 11:18 AM
how do you adjust a spark plug with no tip, like a rotary engine plug???
AJ's Shinka
05-11-2008, 11:57 PM
Umm I just change out my stock with a brand new stock pair of NGK and I widened the gap because the DIY said I could widen it to .059 (leading) and .055 (trailing) I adjusted them to .040 (which was wider than what they came out of the box) but you say they come out the box at .048. I hope I didn't mess anything up.:banghead:
AJ's Shinka
05-12-2008, 01:13 AM
Thanks Ray, I'll go back in tomorrow and fix em.
