Rectangle holes in trunk (under the liner)
Old Sep 13, 2004 | 04:23 PM
The_Bean's Avatar
The other day while doing suspension work I had the truck liner removed and I noticed two holes (one on each side) covered with a thin flap that opened towards the exterior of the car. It seems like much of the noise that comes in through the trunk may be coming in through these flaps.
Anyone know about these? What they are there for? I'm thinking of putting dynamat extreme over them.
Ben
Old Sep 13, 2004 | 09:27 PM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
It could be drainage holes to let water exit the bottom of the trunk.
Old Sep 13, 2004 | 10:51 PM
another8owner's Avatar
air pressure release holes. usually covered by rubber flaps on theoutside portion, when you shut your trunk these holes allow the trunk to shut easier, otherwise you would feel the air pressure in the trunk fighting back making the trunk difficult to shut and causing possible damage to your speakers by over excurting the cone surface and over streching their surround material.
Old Sep 14, 2004 | 12:35 AM
StealthTL's Avatar
Metatron
Heater air outlets.....
They are the outlets for all that air the fan blows in.
Where did you think it goes?
Dynamat them shut, then see if you can get any air from your heater.....
S
Old Sep 14, 2004 | 06:58 AM
LBrx8fan's Avatar
WOW, you guys are smart, that is why I love this forum. I learn something every day on here.
cliffkemp
Dec 24, 2024 10:48 AM
Jst4fun
Apr 17, 2021 07:43 AM
GK1707
Sep 27, 2015 07:33 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
