Mazdaspeed Short Shifter Installed...
Old Sep 4, 2004 | 09:11 PM
cortc's Avatar
Post Mazdaspeed Short Shifter Installed...
Well I installed the Mazdaspeed short shifter today, it was pretty straight forward and I have practice removing everything since installing the lighted ****, parking brake handle and light weight flywheel...
You will need a phillips screw driver, small flat blade screwdriver, needle nose pliers and a small socket with an extension and 10, 12mm sockets...
Here are some pictures, I will post some install steps and an overall impression later...
Attached Thumbnails Mazdaspeed Short Shifter Installed...-ss1.jpg   Mazdaspeed Short Shifter Installed...-ss2.jpg   Mazdaspeed Short Shifter Installed...-ss3.jpg
Old Sep 4, 2004 | 09:13 PM
cortc's Avatar
Some more...
A few more of the install...
Attached Thumbnails Mazdaspeed Short Shifter Installed...-ss4.jpg   Mazdaspeed Short Shifter Installed...-ss5.jpg   Mazdaspeed Short Shifter Installed...-ss6b.jpg
Old Sep 4, 2004 | 09:18 PM
cortc's Avatar
More...
A few more...
Attached Thumbnails Mazdaspeed Short Shifter Installed...-ss7.jpg   Mazdaspeed Short Shifter Installed...-ss8.jpg
Old Sep 4, 2004 | 10:02 PM
How much has it shortened the shift throw?? It's short already...must be really short now
Old Sep 4, 2004 | 10:11 PM
Rxdriftingaction's Avatar
post the pic which u install it on.
Old Sep 5, 2004 | 01:11 AM
youngpit's Avatar
cortc you are out of control. (in a good way) what do you do for a living can you get me a job maybe the whole cop thing was the wrong way to go.
Old Sep 5, 2004 | 12:02 PM
cortc's Avatar
More details later, like the advertisement says it's a 20% reduction in travel... It is noticeable and I like the fact that the shifter is now 1/4 higher; it feels even more natural now...
Old Sep 5, 2004 | 12:07 PM
cortc's Avatar
After pics...
Here are two after pics of the shifter, if you compare to the ones before the install you will notice less travel and 1/4 inch higher position...
Attached Thumbnails Mazdaspeed Short Shifter Installed...-ssf1.jpg   Mazdaspeed Short Shifter Installed...-ssf2.jpg
Old Sep 5, 2004 | 03:14 PM
alex's Avatar
SIGSEGV
cortc -- nice, how long did it take you to finish the job? and, is it smooth running up the gears and back down while driving?
alex
Old Sep 5, 2004 | 06:24 PM
RotorManiac's Avatar
Absolute Rotary Madness
the way you explain the whole process everytime you make a new installation is amazing cortc. great job.
the shifter is indeed higher than before, but it doesn't seem as a big deal, its barely noticeable. I assume the illuminated part works perfectly, right?
Sorry, but I don't know much about this aftermarket part, but does it affect top speed/acceleration?
Old Sep 5, 2004 | 06:45 PM
takahashi's Avatar
You may shift faster and get a better quarter mile but I think this is very very nice mod. I am considering it.
Reason: No insurance would know this and certainly not obvious for other RX-8 owner at first but wait until they touch 'my stick' :D
EDIT: cortc, a request: Video of your hand in action on the stick, please ? :D
Old Sep 5, 2004 | 06:54 PM
cortc's Avatar
Thanks guys, and yes it is very smooth up and down the gears, the illumination on the **** works great and since it's only 1/4" it is hardly noticeable and since the travel is less the shifter does not lay down as much so it is more comfortable...
The spacer raises the shifter mounting plate and the new shifter (The one on the right in the pictures has a longer bottom peg that increases its travel… The spacer raises the complete assembly ¼ of an inch and the top portion of the shifter is shorter by ¼ of an inch to compensate some… Once you remove the assembly you replace with longer bolts the spacer and two new paper gaskets and reassemble in reverse order…
The complete process took an hour and that is because I took my time and took pictures, on a 1-10 scale it is about a 4…
Old Sep 5, 2004 | 06:55 PM
hum.. .it's not a big different. the factory one. is short enough to me.
Old Sep 5, 2004 | 06:57 PM
cortc's Avatar
taka: I will try and take a short video within the next few days...
Old Sep 5, 2004 | 07:13 PM
Sky88's Avatar
Nice mod! looks real nice.
Old Sep 5, 2004 | 07:26 PM
cortc's Avatar
Thumbs up Big difference...
Actually, it is more than you think... This is a 20% reduction in total travel, and you can tell right away... It feels much shorter than it actually is, if the total travel measured from the top of the shifter was 100mm before, it is now 80mm; so from 1st to 2nd gear it's a 20mm reduction in travel...
It feels very precise...
Old Sep 5, 2004 | 07:29 PM
Sky88's Avatar
Cortc, how much was it all together?
Old Sep 7, 2004 | 09:48 PM
shaunv74's Avatar
Power!!
Cool. I can't imagine anything shifting any shorter than it is stock. It must be about the same as a 6 way toggle switch.:D
Old Sep 7, 2004 | 10:01 PM
cortc's Avatar
Sky88: Do you mean price?
Old Sep 7, 2004 | 10:05 PM
shelleys_man_06's Avatar
Not anymore
Awesome cortc.
I can't wait for the report. I was initially skeptical about the MS short shifter; the stock throws were short as it is (at least, compared to the 2003 Mustang Cobra).
Old Sep 7, 2004 | 10:24 PM
Cobalt_RX's Avatar
yeah, what did you pay and where did you get it from?
Old Sep 7, 2004 | 10:28 PM
cortc's Avatar
Paid 395.00 from Canzoomer...
Old Sep 7, 2004 | 10:38 PM
Not anymore
That's kind of expensive. I'm sure it's worth it however. Are there any other places that sell the short shift kit for less?
Old Sep 7, 2004 | 10:48 PM
Richard Paul's Avatar
We've been making shifters for other cars now for months. You think this is a good mod??
If there is a market we'll run off 100 parts. Don't know how many parts are in the kit so I can't say how nuch. I'm sure it will be cheaper then that though.
Old Sep 7, 2004 | 10:57 PM
Not anymore
Richard, I think this is a good mod. I plan on taking my 8 to the track, and I want to shave off as much time as I can, especially when shifting. Perhaps you could design one for the RX-8?
