Engine Whistle and the dealer...
Old Sep 3, 2004 | 08:25 PM
Adamrotor's Avatar
Sonic the Hedghog
Hi, there today for the third time I went to the dealer to get the whistle checked out you can mostly hear at idle after driving it and sometimes at shifting ar slow speeds. I have been to the dealer three time they had ordered the wrong part 3 times, and finally got it today and fixed it. Well thats what I asumed and thats what they said it was gone, well I didnt hear it until i got home and popped the hood, its still there but it sounds different, and quieter. Maybe its normal idk but I am going to call the dealer onemore time for the 5th time.
Not actual car
Old Sep 4, 2004 | 01:28 AM
Mr M's Avatar
Evolution of REvolution
Check the vacuum chamber that provides vacuum to the S-Dais.
Old Sep 4, 2004 | 04:04 AM
BlueAdept's Avatar
Moderator
Hmmm...
I have a similar whistle... I think...
I'd be very interested to know if anyone identifies the cause, I've not been to the dealer with it yet, but I will do...
Mine happens somtimes at idle, but mostly at about 3-4K RPM when the engine is under a small load... perhaps 10% power... you can only hear it with the windows open... Somtimes you get a chirp as you change gear as the engine goes off load... sounds a bit like a turbo dump then... LOL.
Old Mar 15, 2007 | 11:02 AM
MNShinka's Avatar
Spread it on!!
Originally Posted by BlueAdept
Hmmm...
Is this whistle a common issue? It appears that I have a similar issue when I shift from 1st-2nd and sometimes 2nd-3rd. It's a cross between a whistle and chirp that happens when the clutch is engaging (somewhere between it fully "in" and fully "out") just as BlueAdept described. Going from a FWD piston driven vehicle to a RWD rotary, I am open to new sounds, but this does not sound normal.
Any new information or thoughts on this? Thanks for the help!
2006 MT Shinka @ 1000mi
Old Mar 15, 2007 | 10:27 PM
Niro's Avatar
I have the same issue...I told the dealer about it when I brought the car in for the recall but when they gave it back to me they said they couldn' thear it. Ofcourse, the sound is still there...and I don't have the time to constantly go to my dealer to take care of something that might not even be an issue.
Anybody know what this could be?
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
Eirulisse
Aug 15, 2015 12:34 PM
PlayInMyWoods
Aug 8, 2015 07:03 AM
